High Output Charging
Old Aug 14, 2017 | 09:50 PM
thefirstbigone's Avatar
thefirstbigone
Default High Output Charging
I have a 2014 Ultra Limited with the standard charging system. I run without the tour pack 99% of the time so I'm down to one pair of speakers in the fairing. I upgraded these to the Boom II system with an amp. This actually works pretty well for me. It's loud enough and I'm about tone deaf enough I'm satisfied with the system. I'm considering adding speakers to the saddlebag lids this winter which will require another amp. One dealer tells me I'll need the high output charging system a second tells me since I run all led lights I will be fine with the standard charging system. Is anyone running 2 Boom amps with the standard charging system and how well does it work?
Old Aug 15, 2017 | 05:37 AM
cpbedor's Avatar
cpbedor
You will not need a HO charge system sir. These amps pull very little from the system. There are fellas here running lots more off a standard system with no issues. Now if you happen to have heated gear, your passenger has heated gear, you run a heated seat and heated grips and have the radio on full blast ALL the time, you might consider it....but probably not.
Old Aug 15, 2017 | 06:52 AM
flcusat's Avatar
flcusat
Just out of curiosity, how many amps is the stock system vs the hight output?
Old Aug 15, 2017 | 07:25 AM
cpbedor's Avatar
cpbedor
Stock rushmore 50A
High output is 54A
Old Aug 15, 2017 | 07:48 AM
flcusat's Avatar
flcusat
Originally Posted by cpbedor
Stock rushmore 50A
High output is 54A
Thank You
Old Aug 16, 2017 | 08:32 PM
tesnevo's Avatar
tesnevo
New battery, yuasa battery GYZ32HL
Old Aug 19, 2017 | 02:15 PM
rlager's Avatar
rlager
Running Boom II audio with three amps in a 2015 Ultra Limited (Fairing, Tour Pack, Saddlebags). Also have heated grips, and use heated gear in the winter. Running with the standard charging system and haven't had any problems. I think I might upgrade to the High Output when the current stator fails (which it will eventually I'm sure) but for now it seems to be working ok.
Grouser62
2014-2024 Touring Models
11
Sep 23, 2016 11:06 AM
matt_eglide
Jan 12, 2015 09:15 PM
scottt
18
Nov 28, 2014 09:38 AM
DieselDave24v
Audio Systems
62
Sep 4, 2014 04:28 PM
chedderbandit
Audio Systems
Feb 23, 2014 02:59 PM
