fm reception
Old Sep 27, 2017 | 08:30 AM
JMJOHN's Avatar
JMJOHN
Sponsor
Hawg ,,,,
if you are still using the stock AM/FM antenna on the tail trunk, and you installed an amp that took out the FM reception, then it is for sure an amp issue, unless you forgot to plug the antenna cable back into the radio, when you installed the amp ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Sep 28, 2017 | 06:58 PM
hawg50's Avatar
hawg50
john,i took the cb unit completely out.would that make any difference?
Old Sep 29, 2017 | 12:51 PM
JMJOHN's Avatar
JMJOHN
Sponsor
Hawg ,,,,
no ,, the CB unit will have no effect on any of this ,,,,,,
however ,, you MIGHT have forgotten to plug the AM/FM antenna back in when you removed the CB module ?
whitlow
Audio Systems
Oct 9, 2016 05:50 AM
G E E
Audio Systems
Mar 20, 2016 08:12 PM
barrygreen
Audio Systems
17
May 29, 2015 06:27 PM
drrandall1
May 21, 2008 03:39 PM
dowork08
May 2, 2008 05:12 AM
