Second amp suggestion.
Old Nov 9, 2017 | 12:18 PM
Briguy1's Avatar
Briguy1
Default Second amp suggestion.
I need an amp suggestion to run two DDw8's in the bags. The amp would go in one of the bags. I currently have the sony XAV-AX100 HU, SS PN 4.900d amp in the fairing, MMats in the lowers, and AD CX 621s in the fairing. I would also like to know how you connect a second amp?
Thanks,
Brian
Old Nov 9, 2017 | 03:09 PM
slyedog's Avatar
slyedog
Thanks,
Brian
Lot of amp options. If you can fit it a JL 400/4 is perfect. Feed a remote and rca under the fuel tank from the head unit, run a power and ground from battery to a anderson connecter, use female/female rca adapters to connect the rca from bag to the ones from head unit, and use a 0g bulkhead connecter to seal everything that runs out the bag. Wrap all in some tessa tape or tech flex and zip tie as much up away from wheel and brake that you can. You also need a couple pair weather pack connectors and route some speaker wire from bag to bag. Use a 3/8-1/2 id grommet for the other bag to rum speaker wire in.
Old Nov 9, 2017 | 05:02 PM
matt76cmich's Avatar
matt76cmich
DD D4 worked for me.
Old Nov 9, 2017 | 05:09 PM
Briguy1's Avatar
Briguy1
Did you you the D.460 or the D.490?
Thanks,
Brian
Old Nov 9, 2017 | 05:13 PM
matt76cmich
Thanks,
Brian
D4, older version of the D4.90
Slye did a lot neater job than i with the quick disconnects. He helped me a lot when i was doing mine.
Old Nov 9, 2017 | 08:07 PM
Briguy1's Avatar
Briguy1
I'm going to assume that the two blue wires(closest to your hand) with the red tips are the speaker wires, the power and ground are connected to the anderson connector, and the rca cables are the ones furthest to the right wrapped in the black material. Do I need to add an additional fuse? Can I connect the remote wire to the same place(cigarette lighter) as my first amp?
Thanks,
Brian
Old Nov 10, 2017 | 06:15 AM
matt76cmich
Thanks,
Brian
Those wires closet to my hand are remote wires. I have my remotes daisy chained from the cigg lighter to amp to amp to amp.
One fuse per amp
And yes, the wires in the back are the RCAs
Old Nov 10, 2017 | 06:24 PM
soupy371's Avatar
soupy371
Slye,
Nevermind, I read the post..
Soupy
Old Nov 10, 2017 | 09:11 PM
Briguy1's Avatar
Briguy1
Oh, my bad. I just realized that the speaker wires stay in the bag.
Old Nov 10, 2017 | 09:47 PM
sponger's Avatar
sponger
They do, except for the ones that have to go to the other bag
