14 to 17 Swap
Old Dec 11, 2017 | 07:08 AM
ssmith9867's Avatar
ssmith9867
Default 14 to 17 Swap
I have a 14 Ultra with the 6.5 touchscreen and stage II amp/speakers. I also have a 17 Street Glide with the 4.3 stock crap. I would like to swap the good equipment from my 14 to the 17 before selling the 14. Before I go through the trouble of tearing off the batwings does anyone know for sure they can be swapped without modification? I am assuming that the radio connections on the bike are the same for all rushmore models but it is a lot of work to pull everything apart to confirm if they are compatible. Thanks. Steve
Old Dec 11, 2017 | 07:18 AM
Babyboy's Avatar
Babyboy
Your 14 to17 goodies swap will be tit for tat as long as it is just audio or body work as the engine and drive line goodies from the 103 to 107 is a no go
Old Dec 11, 2017 | 02:43 PM
MMXIWG's Avatar
MMXIWG
They did change some of the connectors on the harness. For example, the connector that connects in the side cover to power accessories is different between 14 and 17. You should be okay but be prepared just in case.
Old Dec 11, 2017 | 05:22 PM
Babyboy's Avatar
Babyboy
Looks like I better brush up on the newer Rushmore
Mel B
Audio Systems
38
Jan 4, 2019 07:32 AM
nevera7
Audio Systems
25
Feb 21, 2018 10:37 PM
WestTexasRanger
Audio Systems
29
Mar 12, 2017 07:06 AM
sl33py
Audio Systems
Apr 9, 2013 07:43 PM
ftlee20723
Aug 24, 2007 09:26 PM
