I think he's just saying tinker with stuff and see what you can find out. Very little of what we are doing with these bikes has been thoroughly tested by "professionals" so we all benefit from just monkeying around and sharing our stories.
I recall swapping some stuff around one time and my original Motos were only getting a little over 100w and they sounded noticeably warmer than they are known to.
I am sending those 6CX200nd 300watts each for woofer and around 45 watts to the horn. They do well with more power.
Juice
I'm sure they would, the prob is it's a really small fairing. I had to make and mold in a 7"x9"x2" box to the bottom of the inner fairing for the Arc 600 that's pushing the Beyma woofer on 2 channels and the Beyma and PRV horns in the bags on the other 2 channels. I'm using a B52 to power the PRV 8" 600x in the bags, bridged and parallel At 250wx2, and a DSP on top of that. I might have room for an SD250 on one side to push the horns, but it's gonna be close.
ND,
Gotcha, I will do some digging and see what I can find as far a a small 2 channel.
Ideal setup is parallel the woofs and bridge amp at a 4ohm load.
ND,
Juice
From my limited experience, if u over EQ them Beyma CX they don't really like it.
CAF on youtube has a very informative video on trying to help explain what these mean and how you can use them to help choose speakers. One of the reasons that our beloved PRV6MR500-NDY4 plays as low as it does is because it has a Fs spec of 99.8Hz, hence with 75-150 watts going to it it can easily play 100hz and do it loud. I highly suggest to everyone to watch the video, i took notes and watched it a bunch of times and still refer to it often, it has helped me out a lot!!
marco
Quick update, PRV 8MR600X in the bags are frickin awesome, very loud and audible at highway speeds. I'm sending them 250w each, crossed at 80 Hz- 8500Hz. The bass isn't bad either, though not as much as the 8" Forte's, but to me the trade off of bass for volume and clarity is worth it.
