Speaker options?
Old Mar 5, 2011 | 09:12 PM
jwitt52's Avatar
jwitt52
1st Gear
Default Speaker options?
Looking to get an aftermarket fairing for my RKC. Not sure what to get. (2) 6.5's or (2) 6x9's or (4) 5 1/4" speaker arrangements. I like the look of the (4) 5 1/4", but I am unsure of their sound quality compared to a set of 6x9's. Anybody have any experience with either of these set ups? Any pros or cons to either? Thanks for any advice.
Old Mar 5, 2011 | 09:17 PM
Strat HD's Avatar
Strat HD
Bigger is better. You will get more bass with the 6x9's.
Old Mar 5, 2011 | 10:20 PM
twmartin's Avatar
twmartin
I agree. Go with the 2 6X9's. You should get the most bass with that setup.
Old Mar 5, 2011 | 11:27 PM
mkguitar's Avatar
mkguitar
when looking speakers look for the spec for sensitivity- rated in decibels produced by 1 watt power measured at 1 meter
90 dB is average, look for higher number, better than 100 dB.
that will get you a speaker which will produce the most sound for the least electricity from your amp.
Watt ratings are meaningless as to what the speaker produces, it only indicates how much power the speaker will accept with out blowing up.
Look for a frequency response graph...you want to see a line which is fairly flat--- watch out for any peaks in the range above 1000 hertz, this would indicate harsh brightness.
2-way, 3-way? some speakers have tweeters added- great idea- BUT they often have a "passive crossover network" which uses capacitors to filter low frequencies from the tweeters- these can absorb 30% of the power from the amplifier. ( i've seen this type alot in m'cycle shops and displays at bike shows)
( awesome pro set ups use an "active corossover" to electronically separate the treble from the bass. these separated signals are sent to dedicated powers amps and speakers--- so you need 4 maybe 6 amplifiers- oh and add the sub woofer too)
speaker size?
the more cone area the better to produce lower frequencies.--- the concern with oval speakers is that sound waves are not produced evenly--- the voice coil is round and as it moves forward the soundwaves do not form evenly on the ends and sides on the speaker. this may not be crucial in your application---but the only place in the world you see oval speakers is car audio, they were developed to fit under the dashboard or package shelf.
alot of good options can be found at big box store spkr displays
if you happen to find the magic speakers but are worried about weather- paper type cones can be scotch guarded which will resist rain- don't point the car wash sprayer at them.
mike
Old Mar 6, 2011 | 04:17 AM
ericl's Avatar
ericl
I have a set of Hertz 6x9's. No complaints
Old Mar 6, 2011 | 08:33 AM
04 rkcrr's Avatar
04 rkcrr
I just order a fairing went with the 6x9's. Just trying to figure out what brand of speakers, head unit to go with. The amp I want will not be available until June.
Old Mar 6, 2011 | 08:37 AM
Strat HD's Avatar
Strat HD
Yeah, I'm waiting for that amp too! I plan on going with a Kenwood head unit. They have a few models that have a screen that can be read in direct sunlight.
Old Mar 6, 2011 | 04:29 PM
jwitt52's Avatar
jwitt52
1st Gear
I'm not sure what speakers or radio to go with either. I like the Alpine head units because they also sell a very small 45x4 RMS amp that only works with their head units. As far as speakers I've been looking at the Polk or the Infinity 3 ways. I'm really not sure what is good and what is not any more. I haven't messed with any stereo stuff in years.
Old Mar 6, 2011 | 04:46 PM
GLACIERPEARL's Avatar
GLACIERPEARL
If you're looking at 6 X 9's,...the Pioneer PREMIER line is rated as one of the best. I know that the 4 in my saddlebags make that thing B-O-U-N-C-E !!!
Good luck in your choices !
Old Mar 6, 2011 | 04:53 PM
Bdhouse61's Avatar
Bdhouse61
I had a detachable dragonfly fairing on my last bike, a 2000 FLHRCI that had the Kenwood along with Kenwood 6x9's......very impressed with the sound w/o an amplifier unless the model of stereo I had had a built in amp, I'm not sure........anyway IMO was bettre than 5.25's I had heard and looked better too.
5280Ruffian
Audio Systems
19
Nov 29, 2020 01:53 PM
refg3880
Audio Systems
20
Oct 21, 2016 04:28 AM
Jukebox
Audio Systems
16
Apr 3, 2015 07:13 AM
Street_Glyding
Audio Systems
28
Apr 14, 2014 02:50 PM
stbobfisher
Audio Systems
Aug 23, 2013 06:30 AM
