Help with DMM gain setting
Old Jan 20, 2018 | 12:40 PM
Cheesehead_13's Avatar
Cheesehead_13
Default Help with DMM gain setting
Ok, never did this before and having a tough time, but looking for guidance. Aquatics HU, JL 280/4 bridged in stereo, DDAW's. Trying to set gains with DMM.
  • Amp out FR- taped to black lead on DMM
  • Amp out FL+ taped to red lead on DMM
  • DMM set to ACV
  • Volume on HU set to 30/40
  • 1000 hz test tone downloaded from sticky at top of forum
  • Power on, test tone playing: max voltage showing is 15.4 volts. I believe bridged should be 23.7v per the installation guide.
Any ideas wtf I am doing wrong? It's driving me nuts. There is no way that it should be .5x23.7=11.8v per side is there?
Thanks in advance.
Old Jan 20, 2018 | 12:51 PM
Tailwind's Avatar
Tailwind
Input voltage switches.
T
Old Jan 20, 2018 | 12:54 PM
Cheesehead_13
T
on DMM?
Old Jan 20, 2018 | 12:58 PM
Tailwind's Avatar
Tailwind
Originally Posted by Cheesehead_13
on DMM?
Amp
T
Old Jan 20, 2018 | 01:04 PM
Cheesehead_13
Amp
T
currently on low. Should I set to high? Do i leave it on high once gains are set?
Old Jan 20, 2018 | 01:11 PM
Tailwind's Avatar
Tailwind
Typically in low but depends on your wiring setup. Turn gains all the way down and see what impact it has in high v low.
Also make sure ur DMM is reading VAC.
T
Old Jan 20, 2018 | 01:23 PM
Tailwind's Avatar
Tailwind
Are u wired 4 channel bridged? Switch at 4 channel input?
Gator clips on correct wires?
T
Old Jan 20, 2018 | 02:09 PM
Cheesehead_13
T
Low voltage input, 4 channel (bridged in stereo),filter at 80hz, filter mode hp
DMM taped to wires from amp
DMM set to VAC (ACV)
Old Jan 20, 2018 | 02:10 PM
Cheesehead_13
T
no difference high vs low input
Old Jan 20, 2018 | 02:48 PM
Cheesehead_13
No difference with bike running or not running. I have no idea what's up.
