Amps
Old Jan 27, 2018 | 09:58 PM
DAVENRINO's Avatar
DAVENRINO
Originally Posted by USAproud
Polks are 4 ohm and kappas are 2 ohm. Plenty of power at 2 ohm but a little underpowered to drive those polks to there potential. Just based on what I see on specs with no real world experience with amp.
Pretty much what I was thinking.
Old Jan 28, 2018 | 06:57 PM
Bafflingbs's Avatar
Bafflingbs
The Rockford amp is understated at 100w per channel. I believe they are the only manufacture that does this. The real out put is probably closer to 120w per channel at 4 ohms and 130-140 at 2 ohms. The birth sheet that comes with your amp will show it's true rating in RMS. Mine is on the lower side, with 450 watts at 4 ohms and 532 watts RMS at 2 ohms. So, if you're lucky enough to have a vender at a bike rally or in town, that will let you open the box and see the sheets, that would be awesome. Because then you can pick the one with the highest output. I've seen them as high as 570 something. So yes, this amp will be fine. for those speakers. I have the mm692's, and they rock! Even at 112.5 watts. But then again, they can take 150 watts RMS, sooooo.
JMC22
Audio Systems
23
May 30, 2020 12:02 PM
kblackmon
Audio Systems
Oct 18, 2016 02:04 PM
uplandpinter
Audio Systems
May 1, 2014 04:51 PM
SecondChance!!
Jan 31, 2014 12:19 PM
reesestewww
Audio Systems
31
May 9, 2013 05:41 AM
