Rockville woofer
Old Mar 7, 2018 | 04:07 PM
Delgado130's Avatar
Delgado130
Default Rockville woofer
I`m running B3 horns and Mmats in fairing. American bass 6.5`s in lowers and Pioneer Pro`s in lids. I will be replacing Ab with another set of Mmats. Powering this one Pn4.1000d. My sound is loud and clear. I have another Pn4.1000d just laying around so I was wondering how the Rockville RVL69W 6x9 woofers would sound. My Pro`s have a nice end but I`m not getting as much highs I think because of my plastic covers are blocking them. A guy in my club has them with cloth grills and the highs are almost too loud! So with that being said I`m not worried about losing those frequencies, the B3`3 have more than enough. Has anyone on the forum tried them out or will I have to be the guinea pig? I`m not looking for sq in the rear I`m looking for more low end and midbass. https://www.ebay.com/itm/2-Rockville...8AAOSwySVaHnvn
Old Mar 7, 2018 | 04:14 PM
SBates08's Avatar
SBates08
Damn that magnet may cause some trouble. Looks deep as hell.
Old Mar 7, 2018 | 04:51 PM
Moto Mike's Avatar
Moto Mike
Thinking the same thing Bates..my HAT and DD 6x9's barley cleared the bags! The horns on the pro's should be blasting you off the bike,,,lol...like your club member! DD VO 6x9's will give you more mid bass but not near the highs of the Pioneers!
Old Mar 7, 2018 | 06:07 PM
azlou66's Avatar
azlou66
Features:
Rockville RVL69W Competition 6x9 300W Peak / 150W RMS woofer
Power Handling Per Speaker: 300 Watts Peak / 150 Watts RMS Per Speaker
9 pounds each!
6 x 9" Single Voice Coil 4 Ohm subwoofer
Plays extremely loud mid-bass and low frequencies
Double 60oz. Double Stacked Magnet Structure
2" High Temperature Voice Coil
Frequency Response: 50Hz-8KHz
Sensitivity: 92db @ 1W/1M
Mounting Depth 4-3/4"
Butyl Rubber Surround
Non-pressed Paper Cone
Cutout diameter: 8.9" x 6.1"
Mounting hole diameter: 4 holes - 0.263" x 0.33"
Specifications:
Application: 6x9" Midrange Speaker
Basket Type: Open, Expanded Aluminium Basket
Dustcap: Phase Plug Bullet
2" High Temperature TIL + CCAW Voice Coil
Impedance: 4 Ohm
Overall Depth: 4.8inch / 122mm
Mounting Depth: 4.57inch / 116mm
TS Parameters:
Revc: 3.2 Ohm
SPL: 85.1 dB
Fo: 52.3 Hz
Vas: 9.966 Ltr
Cms: 151.653u M/N
Md: 50 g
Krm: 1.010K uOhm
BL: 9.713 Tm
Erm: 0.993
Qms: 4.067
Mms: 61.167 g
Qes: 0.681
Mmd: 59.353 Kg
Qts: 0.584
Kxm: 31.844 mH
No.: 0.202 %
Exm: 0.65
Rms: "4.938" kg/s
Piston Diameter: (Oval) 201.5 x 136 mm
Le:1.518 mh
Vd: 150.584 cu. cm
Sd: 21.512 sq. cm
Old Mar 7, 2018 | 06:23 PM
Babyboy's Avatar
Babyboy
The mounting depth is ridiculous and also at almost 10 pounds a piece good luck getting the lids to function and if you do hang on tight when you get that lid open because you might rip the bag off the bike or even worse flip the bike over.
HOLY MAGNET
Old Mar 7, 2018 | 07:05 PM
tesnevo's Avatar
tesnevo
Damn that, some has to try these now!!! I’ve got to know how they sound....
Old Mar 7, 2018 | 07:35 PM
Moto Mike's Avatar
Moto Mike
There you go Tes..throw them in your new build...we can all hear em at the MM&G...lol!
Old Mar 8, 2018 | 06:52 AM
Delgado130's Avatar
Delgado130
I actually had to bottom mount the Pro`s because of the horn. I can top mount the Rockvilles. I may can add a spacer also since there is protruding tweeter
Old Mar 8, 2018 | 05:13 PM
tesnevo's Avatar
tesnevo
Lol, hell I don’t have anything with holes open for them... someone needs to man up and run a set. I bet they would flat out thump in the rear deck of a car
Old Mar 9, 2018 | 07:22 AM
Delgado130's Avatar
Delgado130
I just ordered a set. I will let everyone know how they work out next week.
