Ready to install
Old Mar 20, 2018 | 09:03 PM
DAVENRINO's Avatar
DAVENRINO
Originally Posted by DAVENRINO
Aloha,
Heading to OR Thursday to do some work on my 16 Limited and I am sure I will need some help from the experts. I have a Focal sport amp, AW6.5/BT30 for the fairing and MM652 for the TP pods. I also have the BT brackets and 2 LL with the breakout harness. I also ordered the PAC TR4 in case I need it.
My first question is regarding water-resistance of the fairing speakers. I already made cutouts in the Hogtune grills to mount the tweets. I know the AWs have aluminum cones, so do I need to do anything else to help prevent water damage?
Next, do I need to connect the amp turn on wire or will the signal come from the Boom 6.5 HU through the Breakout harness? PAC TR4?
TIA,
Dave
Thanks for the help HAZE and JMC. That just leaves the turn on signal question for now. If I need one and use the PAC TR4 would I use a speaker wire for the signal? If so, which one? Would that allow me to turn off the amp by turning off the speaker switch (assuming my bike has one). I haven't seen my bike since Oct but my old UC has one.
Old Mar 21, 2018 | 09:53 AM
JMC22's Avatar
JMC22
Within the 9 wires that come out of the amp speaker REM harness (4 you will use for the front speakers (white & gray) - 4 you will not use unless you run rear speakers(Green & purple) there is a blue wire - I spliced this wire into my cigarette wire to turn the amp on using disconnect in the pic
Attached Thumbnails Ready to install-10pcs-splice-wire-connector-scotch-lock-quick-connectors-terminals-crimp-electrical-car-audio-wi.jpg
Old Mar 21, 2018 | 12:31 PM
DAVENRINO's Avatar
DAVENRINO
Thank again JMC.
ScottBrosRacing
Audio Systems
21
May 9, 2019 10:45 PM
Harleypingman
Audio Systems
131
Jun 14, 2016 07:03 AM
WallyWhite
Audio Systems
Nov 11, 2015 10:03 AM
Scooby1426
Audio Systems
13
Jul 18, 2015 03:14 PM
Pioneer74
Apr 29, 2012 07:14 PM
