Are DSP's Lord Voldemort?
Old Apr 13, 2018 | 02:17 PM
DE-Glide's Avatar
DE-Glide
Originally Posted by Tailwind
Ur floor noise is inherent with the ARC PSM.
Gain v master gain v output v EQ.
High level into the ARC has also been know to mitigate it a bit.
T
Thanks!
Yes I noticed that it increased with the latest iteration of the sound system. Previously I was using high level inputs and didn't notice it as much. Gains set using SMD-DD1. 0db 1000Hz for head unit, -5 db 1000Hz for the PSM and Amp gain settings. It is only really noticeable at low or no volume.
Thanks for the input.
Old Apr 13, 2018 | 02:24 PM
Tailwind's Avatar
Tailwind
Originally Posted by DE-Glide
Thanks!
I think some of the tech nerds at ARC recommend the master gains to be in the -10 range or possibly less but there seem to be tons of different ways to currently skin this cat.
T.
Old Apr 13, 2018 | 02:36 PM
DE-Glide's Avatar
DE-Glide
T.
Wow! that's a big difference from what I have it set at in the PSM
Fronts and Rears at + 5.5 (where the SMD-DD1 shows distortion at -5 db 1000Hz), then very little gain at the Arc 600.4 amp
Horns set at -10 (Small kenwood amp had no gain control) still has some small gain hiss at low/no volume
BTW I have all of this crammed in the fairing of a 15 Road glide (except for the VO-M6x9s that are in bag lids) so getting to the gain settings of the Arc 600.4 is going to be a nightmare again.
Old Apr 13, 2018 | 03:25 PM
azlou66's Avatar
azlou66
It could be a factor as well but I don't know much about the DSR. If the things mentioned above are not in sync then the DSR could very well be the culprit.
I'm no DSP expert and throwing darts here but based on what I have seen in the DSP world is a simple scenario where the amp gains are high and the DSP is having to pull everything down or vice versa where the amp gains are too low and DSP is working too hard. Find a balance seems to mitigate some of the exposure.
T.
More food for thought, thanks T.
Old Apr 13, 2018 | 03:33 PM
cshocker's Avatar
cshocker
I have a ton of floor noise with my ARC. Tried a few different settings. So I thought about it for.......about 2 seconds and just decided to crank up the tunes and leave it! I don't hear it then .
Old Apr 13, 2018 | 04:41 PM
Tailwind's Avatar
Tailwind
Anyone using a subtractive EQ strategy vs additive EQ strategy?
T
Old Apr 13, 2018 | 05:44 PM
azlou66's Avatar
azlou66
I am, for now at least.
Old Apr 13, 2018 | 05:52 PM
azlou66's Avatar
azlou66
I prefer to use subtractive as my baseline then additive to fine tune if needed.
Old Apr 13, 2018 | 06:46 PM
Tailwind's Avatar
Tailwind
Very cool!!!! That has seemed to help the floor noise as well. Cleaner tunes as well.
Prob 1000 ways to break the code but I'm enjoying tinkering with and learning the various strategies.
T.
Old Apr 13, 2018 | 07:55 PM
bubisa050's Avatar
bubisa050
2nd Gear
DSPs are more like the dementors Scary and when around they suck the joy out of you
I tried using them a bit, thinking I will get a hang of it eventually, but it doesn't work that way :/
