While I'm not very adept and dsp experienced as many here, I can surely vouch for the extreme variables between systems and sources.
Just the sound differences between audio files on a usb makes a huge difference. Then you factor in variables like fm or SiriusXm or Streaming, and the tune goes all over the board. I can make any one of those sources sound fairly well, all things considered. Usb although sounds the best. I think you would be hard pressed to get ALL of the available sources to sound equally as well.
Hey I'm not picking on anyone here, but that's a very myopic and simplistic way of going about this because it's only specific to Q and it's function as it relates to the output of the DSP, and does NOT address or account for what freq the speaker naturally spikes at, the impendence curve of what frequencies play louder than others, if there is any colouring of the amp, etc. Then couple what I just mentioned and other contributing factors with a DSP that has 31 bands vs. 7 bands AND different speakers and the equation AND results will change every time. Even the smallest things like radio being used changes how something is Tuned.
AND....while i'm being open here and this is not specific to any comment recently posted by anyone. My 100% honest opinion is that sharing files does more harm than good because baselines setting with so many other variables will NEVER work.
I think that was the entire point of the caveman overview. Psssst. Caveman = simplistic.
It's like baking a cake brother. U have to identify and define all the ingredients before u start mixing shix up and baking the cake.
Good luck boys!!!! Maybe the disc jockey forum will be a better source for this EQ stuff.
Can I make a sugestion. I'm sure your neighbors won't appreciate it but tune you system in the drive way not the garage. It will be somewhat closer to the driving enviorment as you won't have sound reflecting off the walls and ceiling which will change the sound.
That's what I enjoy most about living in BFE. Nobody to **** off but the critters.
