More research questions
Old Apr 27, 2018 | 07:30 AM
Stew_FL's Avatar
Stew_FL
Default More research questions
A few more questions if you please.
1) Anyone have problems using speakers that are not water resistant/waterproof?
2) How much ca-rap can you fit under a 2017 Batwing fairing without mods?
Big amp and a DSR1?
3) What is the bigest amp that fits.
(Size not watts) without mods.
Old Apr 27, 2018 | 07:51 AM
InthewindMN's Avatar
InthewindMN
The pods limit things some. If you go to BT brackets you can fit 2 amps and a dsp in the right combination. I have a JL xd400 on the factory amp tray with room to spare. I’m using the factory pods. I could still squeeze in a micro amp in the cb hole and possibly a psm. The JM amp tray gives you a larger amp footprint.
Old Apr 27, 2018 | 10:28 AM
Tailwind's Avatar
Tailwind
Hertz HDP is the biggest I have had on the JM Tray. Without the HD speaker pods u can also fit a JL280/4 or similar sized amp vertically on the clutch side of the BT bod remover bracket and also a JL280/4 sized amp in the CB hole. The ARC DSP will fit on the brake side of the BT bracket vertically with some industrial Velcro.
Reasonably sized crossovers beneath each 6.5 speak.
T
Old Apr 27, 2018 | 10:34 AM
InthewindMN
T
Does the jm tray change the size of the cb hole?
Old Apr 27, 2018 | 11:16 AM
MMXIWG's Avatar
MMXIWG
T
Thanks T! Very helpful info.
Old Apr 27, 2018 | 12:16 PM
black01's Avatar
black01
If it does, its not much. I have a 600/6 on one with a SD250.2 in the cb hole. With the Bt brackets I still have room for an amp on the clutch side and DSP on the other if I want to add either or both.
Old Apr 27, 2018 | 02:13 PM
Juice's Avatar
Juice
T
T.
Do you happen to have a pic of under the hood?
Old Apr 27, 2018 | 02:19 PM
Dsm Limited's Avatar
Dsm Limited
I have an arc Moto 600 on the Factory tray. I have an arc PSM on the angle of that same tray on the clutch side. And I have a n vx400 in the CB hole with the factory pods in place
Old Apr 27, 2018 | 02:22 PM
InthewindMN
Id like to see a pic of that.
Old Apr 27, 2018 | 03:26 PM
Dsm Limited
I'll get you a pic this weekend. I need to make a couple wire changes for the PSM.
Stricnine
Audio Systems
Feb 18, 2018 09:13 PM
daveblank
Audio Systems
Jun 21, 2017 05:35 PM
AAWAV
Audio Systems
11
Feb 6, 2015 01:00 PM
Da Shadow
Audio Systems
Oct 20, 2013 01:48 PM
loco2355
Dec 22, 2009 11:12 AM
