headset electrical interference
Old May 9, 2018 | 08:40 AM
cincyfirefighter's Avatar
cincyfirefighter
Stage II
Default headset electrical interference
I have a 2011 FLHTK with the factory intercom system. I put Love Jugs cooling fans on my bike and they are powered thru the factory ACC. connector under the seat. I am getting "noise" in the headset when plugged in the front"driver" location but no interference in the passenger headset. I have factory boom audio headsetsand have tested both in both positions. Only the front connection is exhibiting interference. This all goes away when the assessory switch is turn off killing power to the fans. My bike is all stock with no none harley accessories and the fans are the only thing connected to the accessory system
Old May 9, 2018 | 08:42 AM
cfave's Avatar
cfave
How are you grounded?
Old May 9, 2018 | 08:59 AM
cincyfirefighter
Stage II
The Love jugs fans ground thru the ACC. system. I have checked all the grounds in the bike that i can find. should the fans have a ground seperate from the ACC. plug?
Old May 9, 2018 | 10:51 AM
cfave's Avatar
cfave
I would suggest to try that first. If you can run it to the negative post of the battery or a grounding post by the battery. I would think that would alleviate the buzz.
tbarcia
Aug 10, 2017 11:49 AM
bunotz
Jul 15, 2012 08:53 PM
Rudy046
Jun 25, 2011 06:35 PM
sweet07
Nov 24, 2007 02:30 PM
Grayhawk
Sep 17, 2007 11:25 PM
