CB
Old Sep 16, 2007 | 08:07 PM
Grayhawk's Avatar
Grayhawk
Default CB
I use my cb with a helmet headset and use the push to talk feature. When I push the button in to use hte cb I get all kinds of static through my headset. So much that I can't stand to use it. THe people on the other end says it sounds good to them. When my passenger uses her push to talk button for the cb she gets all kinds of static. My battery got hot shorted out and melted the negative post. I wonde rif that hasd something to do with it? Do oyu guys know what it could be?
Old Sep 16, 2007 | 08:22 PM
MACK's Avatar
MACK
Default RE: CB
WHAT YOU SAY COULD BE THE PROBLEM. BUT TRY CLEANING THE CONTACT PINS OF YOUR UNIT. THAT USUALLY HELPS. SOUNDS LIKE YOUR CONTACT PINS ARE DIRTY OR CORRODED FOR THE INCOMING SIGNALS.
Old Sep 16, 2007 | 09:25 PM
Grayhawk's Avatar
Grayhawk
Default RE: CB
Are the pins in the handlebar control housing?
Old Sep 16, 2007 | 10:00 PM
JMJOHN's Avatar
JMJOHN
Sponsor
Default RE: CB
GrayHawk ,,,,,
that does not sound good at all ,,,,,
did this all start after the battery was melted ? ,,,,,, I think what you are hearing is the intercom portion of the system making noise when you try and talk on the CB ,,,,,, and a portion of the audio system could have been damaged when the dead short occuredat the battery ,,,,
what caused the short ?
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Sep 17, 2007 | 06:24 AM
Capt.Bob's Avatar
Capt.Bob
Default RE: CB
I get some static when I use the PTT button also. Mine has done this since new. I don't hear it when I am running down the road and everyone says my radio sounds fine.
Old Sep 17, 2007 | 11:25 PM
goodbirds's Avatar
goodbirds
Default RE: CB
check the ground on the radio system at the antenna. Especially on the plate under the liner in the trunk. The cables are shielded to avoid static but if the ground isn't good, the shielding doesn't work.
lowriderr9
Jul 1, 2019 04:41 PM
striper.seeker
Audio Systems
Jul 26, 2016 01:14 PM
RobN
2014-2024 Touring Models
Apr 2, 2015 04:11 PM
powaypete
Jan 30, 2010 10:01 AM
kpb46
Jul 15, 2007 10:05 PM
