amp choice
Old May 30, 2018 | 08:16 PM
5280Ruffian's Avatar
5280Ruffian
Originally Posted by Sturgis67
That amp will fit fine, no cutting of anything, except wires. The one I have (PA RZ4-2000d) there are plastic pieces on either end of the amp that need to be removed (4 screws) but NO bike mods. Not sure about the amp mounts, Velcro it to the top of head unit and go.
Do you have any pictures of your installation? And this is the same amp as the Soundstream PN4.1000D, right?
Old May 31, 2018 | 07:52 AM
Sturgis67's Avatar
Sturgis67
Basically the same amp. Sorry bad timing on the pictures, I just took it apart last night to put in a new head unit. Many folks have done this, maybe one of them can share a pic. With most amps you put in you will need to move some wires around. Sorry I couldn’t help more.
Old May 31, 2018 | 09:05 AM
yooperhog's Avatar
yooperhog
i was under the assumption that the PA rz3000 was the sister amp to the SS PN4 1000
Old May 31, 2018 | 10:11 AM
SBates08's Avatar
SBates08
You are correct. The rz2000 is the same as the SS pn4.520.
Old May 31, 2018 | 10:24 AM
Sturgis67's Avatar
Sturgis67
thank you for the correction gents. My mistake.
Old May 31, 2018 | 12:03 PM
madhunter60's Avatar
madhunter60
i'm with Yooperhog, cerwin vega b52, will do the trick at your price range, and only a 2 speaker setup.
https://www.sonicelectronix.com/item...-Vega-B52.html
Old May 31, 2018 | 04:31 PM
5280Ruffian
Thanks everyone for the replies!
I want the option to add lower speakers, so a 4 channel amp is paramount.
Old May 31, 2018 | 04:42 PM
SBates08's Avatar
SBates08
Originally Posted by 5280Ruffian
Thanks everyone for the replies!I want the option to add lower speakers, so a 4 channel amp is paramount.
Don't go with the Cerwin Vega B54 then.
Old May 31, 2018 | 04:43 PM
5280Ruffian
Really? Why is that?
Old May 31, 2018 | 04:46 PM
SBates08's Avatar
SBates08
Most folks go with 4ohm speakers to build their systems. The B54 only puts out 80 watts at 4ohms. Severely anemic for 4ohm applications.
