Sound cuts out When I use throttle
Old Jun 5, 2018 | 04:38 PM
hoggzzer's Avatar
hoggzzer
Default Sound cuts out When I use throttle
2015 Ultra limited. Sound cuts out as soon as I touch the throttle. Throttle works fine to ride. Doesn't cut out with just the ignition switch on.
Upgraded sound system.
Put on new bars a couple weeks ago.
Also put on Ciro fangs over the weekend.
All was good until yesterday.
HELP?!!?
Old Jun 5, 2018 | 09:47 PM
Dsm Limited's Avatar
Dsm Limited
That's an easy fix...... don't use the throttle. Seriously though, If I had to venture a guess, I'd say a loose connection at the amp. It could be any of the connections for main power, ground, remote turn on or speaker input to the amp. I'd pull the fairing, and start the bike and check for power loss with throttle use first.
Old Jun 7, 2018 | 04:39 PM
hoggzzer's Avatar
hoggzzer
Update....after hours of frustration...
Pulled fairing and checked all amp/rca/speaker wires.
Checked ground and redid wires on fuse pod for power wire to amp.
Intercom off.
CB off
Reset HU to factory settings.
Pulled fairing to recheck plugs coming out of new bars.
As far as i KNOW ALL HANDLEBAR CONTROLS WORK AS THEY SHOULD.
I NEED HELP HERE FOLKS.........................
Old Jun 7, 2018 | 05:14 PM
SBates08's Avatar
SBates08
Are you using the AVC function?
Old Jun 7, 2018 | 05:25 PM
hoggzzer's Avatar
hoggzzer
No. It’s off.
Old Jun 7, 2018 | 07:15 PM
SBates08's Avatar
SBates08
Aight gimme the specifics of your upgraded audio. Did this start as soon as the bars were installed and did the dealer install the bars?
Old Jun 7, 2018 | 08:10 PM
hoggzzer's Avatar
hoggzzer
Amp soundstream pn4 1000d
db motos in TP and fairing.
PRVs in wet lowers.
All new speaker wires run.
Old Jun 7, 2018 | 08:41 PM
SBates08's Avatar
SBates08
Have you checked the NAV prompts?
Old Jun 7, 2018 | 08:55 PM
hoggzzer's Avatar
hoggzzer
no i havent.
i did bars and stereo. bars 3 weeks ago all was good til tuesday.
Old Jun 7, 2018 | 09:11 PM
SBates08's Avatar
SBates08
Go into your NAV and see if the prompts are on. That could be what's causing your issues.
