so..minimal..what amp would suffice to run the 165 and the 690.
gypsy...the 6900 are just in case.
I only want to purchase one amp and I'm trying to get this right the first time.
first order of biz is to figure out what amp for the 165/690.3. if I have to add another one later for the ts6900 then I can cross that bridge then.
honestly, I know zilch about stereo equipment so I am relying on the expert for guidance.
just like I rely on FM, hillside, kirby and the rest of the engine building experts for engine building guidance.
thanks for all comments and/or suggestions...it is much appreciated.
If you want to buy once and you may end up with 6 speakers and you want it to fit in the fairing, buy the Focal Sport.
If you want to fine tune all that good stuff I have a Rockford Fosgate DSR1 for sale.
By the specs it should and I like that all connections are out front instead of on the sides. I have not run one of those but it looks good. A bit $$ though.
