Does your fade work? I’ve heard of people getting it on the screen but it doesn’t function without the boom amp. I haven’t done any experiments with different flashes so I’m only going off what I’ve read, which could be bs.
Good question I was under the impression that you lose fade control with all of the “flat” flashes.
The dealer can still do 0 amp 4 speaker (stock Ultra Flash) and will get you fade control. It's not a flat eq flash.
The way I understand it, the 2 amp 8/ 6 speaker is the flat eq flash you'd want, but not available at the dealer unless they are doing a Boom 2 install and an amp is installed. Their program won't allow it now, but it used to.
The aftermarket world can still flash whatever you want. Haze and Gypsy's company can do those flashes to this day.
I don't know what he meant, he made it sound like it was easy to remove the amp from the HD head unit. At this point I just felt he was talking above my head and didn't press the point, he had been kind enough to answer a lot of my stupid questions already.
