Bridged and parallel
Old Jul 21, 2018 | 11:34 PM
marcodarq's Avatar
marcodarq
Haze and Babyboy have given you some good direction, the only other thing to know is are you using the stock head unit? if so, are you using the BT line levelers, or some other type of loc with the head unit flashed? Haze or I could most likely flash your head unit if you need it and we aren't too far away from you.
m
Old Jul 22, 2018 | 06:06 AM
Rdcris's Avatar
Rdcris
m
Yes I'm using the stock HU and cycle sounds magic box line leveler.
What would a flash do for me?
I have an extra 4.3 head unit. I could use.
Old Jul 22, 2018 | 07:39 AM
haze324's Avatar
haze324
A PN4.1000 fits in top of your headlight. You need to cut the plastic tabs that hold a few connectors in place.
The magic box is old technology and the worse solution these days. It filters out lots of quality sound. A flash will flatten the signal from your radio so you can ditch the magic box.
Old Jul 22, 2018 | 08:18 AM
Rdcris's Avatar
Rdcris
Can the head unit be flashed off the bike? I have another unit for this.
Fullbore55
Audio Systems
Oct 10, 2018 05:33 PM
Hitman-98
Jul 29, 2018 08:32 PM
rblahetka
Audio Systems
Jun 9, 2018 09:56 PM
jdilbeck
Audio Systems
36
Mar 6, 2018 03:59 PM
Da Shadow
Audio Systems
Oct 20, 2013 01:48 PM
