Good to know. I wasn’t aware that it was a sharp cutoff, unlike the typical 12db shoulder of many amplifiers.
So I guess I don’t need high pass filter in the amp.
Good to know. I wasnt aware that it was a sharp cutoff, unlike the typical 12db shoulder of many amplifiers.
So I guess I dont need high pass filter in the amp.
In a situation where your amp (running 4 channels, 2 separate pairs of speakers) is receiving a single input from head unit, front or rear pre-amp outputs on head unit,and the 2 pair of speakers you are running require different cut-off points thru HPF, then you need to use the hpf on the amp.
this usually occurs when multiple amps are used and the front or rear signals from head unit are split to feed 4 channel input of amp.
I hope that makes sense
