Question re:Stock Radio
Old Sep 25, 2018 | 02:47 PM
jmeyer58's Avatar
jmeyer58
Default Question re:Stock Radio
Hi all, I think I have a quick question. I have a 2011 Ultra Limited. Everything I’ve read seems to indicate the radio came with an amplifier mounted under the tour pack. I cannot seem to find the amp, did I get screwed when I bought the bike back in ‘11 or was the amp an option, mounted somewhere else, or...am I blind?
Old Sep 25, 2018 | 03:41 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I thought only the CVOs had the amp standard? Maybe someone with a dealer background could chime in.
It's big enough you couldn't miss it. There was a big L shaped plug that ran a wiring harness back into the bike.
They did make a bracket to mount that same amp under the fairing though if I remember correctly. I think that was for after sale installs though because I think the catalog said it wasn't compatible with the CB module, meaning they didn't make a bracket to relocate it properly. If you have a CB I wouldn't think it would be under the fairing.
Old Sep 25, 2018 | 05:14 PM
SBates08's Avatar
SBates08
The Limited did not come from the factory with an amp. Unless the bike was special ordered with one.
Old Sep 25, 2018 | 05:49 PM
jmeyer58's Avatar
jmeyer58
Thanks guys, I do have the cb and nothing under the tour pack so I assume no amp.
Old Sep 25, 2018 | 07:19 PM
Weeboy1's Avatar
Weeboy1
many here can willingly remedy that dilemma.......
Old Sep 25, 2018 | 07:24 PM
Hoyt 1911A1
Definitely better with aftermarket. If I remember correctly the Harley amp for that model was only 40 watts per channel into two ohms. I think the head unit put out 20 per channel so not a great gain. You can easily stuff an amp under that fairing that puts out a clean 100 watts per channel into four ohms for what Harley charges for their amp.
mrsnipy
Audio Systems
Feb 8, 2017 04:47 AM
mysturgis
Audio Systems
Mar 15, 2016 08:13 PM
Tx_Outlaw
Audio Systems
May 28, 2013 08:41 PM
Geezr Glidr
Audio Systems
Jul 27, 2011 10:04 AM
ElectraLarry
Mar 21, 2010 05:05 PM
