Tuning Continued
Old Oct 30, 2018 | 09:02 AM
  #101
Babyboy's Avatar
Babyboy
Originally Posted by MMXIWG
Any more feedback on the DD DSI-2 yet?
I am using a DSI-2 at the present time. To me it is very user friendly,easy to set up and use.
All the adjustments are on 1 screen. You can tune each channel individually ( peq and crossover) or link them together.
It is either PC adjusted or Bluetooth via the accessory Bluetooth adapter which is extra.
The DSI-2 has 8 channels output you can eq or change and 2 channels pass thru.
The only con I have found about it is if you use a stock Rushmore HU you have to manually change to a different preset if you are tuning 2 different presets.1 for off bin and 1 for run.
It does fit in the CB cubby on the Rushmore batwing.
Old Oct 30, 2018 | 09:14 AM
  #102
Hoyt 1911A1's Avatar
Hoyt 1911A1
The mini DSP software download is $10 I bet you've spent $10 on dummer things lol.
That is certainly true. My one peeve with the miniDSP though is the power supply is just a circuit board with its guts hanging out that you have to wire manually. I don't mind doing it but that seems kind of cheesy to me.
Old Oct 30, 2018 | 09:19 AM
  #103
marshallb's Avatar
marshallb
I think that's why it's a $100. The idea behind the mini DSP is to be economical.
Old Oct 30, 2018 | 10:19 AM
  #104
Hoyt 1911A1
The software for the miniDSP appears to actually be a browser plugin. Here is a video of it in action:
It seems to me to be a good value for the money. I just feel like from what I am seeing it may be overkill for what I want to do, but there could be worse problems.
I really like the app for the Stetsom unit though. Do y'all think I could just use the parametric EQ as a notch filter for the fairing speakers? I don't speak Spanish but here is a video of the app in use:
Old Oct 30, 2018 | 10:44 AM
  #105
MMXIWG's Avatar
MMXIWG
Thanks for the feedback. I saw comments in another thread about not being able to tweak voltages like the ARC PSM so I was wondering if that was an issue. Manually changing presets wouldn’t bother me as I would leave mine tuned for running 99% of the time anyway. I really want something that has Bluetooth and is small enough for the cubby or clutch side of BT brackets.
Old Oct 30, 2018 | 11:14 AM
  #106
Babyboy's Avatar
Babyboy
You cannot change the voltages on the DSI-2.
When I initially installed mine and check the output voltage of the DSP I was getting 4.5 volts with the Boom 6.5 HU wired in as high level inputs.
Here a a couple pictures of the fitment in the cubby
Old Oct 30, 2018 | 12:22 PM
  #107
Hoyt 1911A1
That DSI-2 looks like a real nice unit. It is just too big for the space I have at the moment, and I really only need four channels at this time. How much do those things cost? I'm not finding much as far as pricing goes on the Internet, they mainly say to contact a dealer. That leaves those of us out in BFE out of luck.
If someone wants to increase the input voltage to a particular amp I have had good luck with the PAC LD-10 line driver. The TM400x4ad I have powering my rear speakers is basically set for speaker level outputs with no switch to select low level. They actually tell you to cut off the RCA plugs and splice in your speaker wires with no other changes, so that tells the tale right there. The LD-10 gave it a fat enough signal to where I didn't have to crank the gains up to where it made the speakers hiss.
I realize that one module isn't a good all in one solution but if you only have a few inputs that need boosting it is cheap, small, and works well.
Old Oct 31, 2018 | 08:13 AM
  #108
Hoyt 1911A1
Here is a video of a guy going through all the settings of the miniDSP 2x4. He is a bit of a potty mouth but he really digs in deep with the adjustments.
One thing I was curious about was the EQ adjustments. Each input has it's own parametric EQ with five settings each. Each of the four outputs has their own parametric EQ with five settings each. The thing I wonder is can you get a basic "smiley face" EQ curve with a parametric equalizer or are they basically notch filters so to speak?
Old Nov 1, 2018 | 05:54 PM
  #109
flcusat's Avatar
flcusat
The video on the Stetsom is not in Spanish by Portugese
Old Nov 1, 2018 | 07:18 PM
  #110
Tailwind's Avatar
Tailwind
Obrigado!!!
T
