PRV setup. Trying to figure out tweeter options
Old Nov 7, 2018 | 10:25 PM
IndyNick's Avatar
IndyNick
Default PRV setup. Trying to figure out tweeter options
Starting another project for a friend. 2018 SG. Going with PA setup. He wants loud! Going with 2 8” PRV mb600’s in the bags. 6mr500’s for fairing. No lids. Just trying to figure out tweeter options. I’m assuming I’ll need horns to compete with the fairing speakers or would a nice dome tweeter flush mounted in hogtunes grilles suffice? Is there enough room with those grilles to mount a horn? Don’t want to do gauges or anything. What are my options? Will probably do a dsp and or flash. Thinking of the Stinger stx4 ch amp as well. Thanks!!
Old Nov 8, 2018 | 08:25 AM
FrenchieM's Avatar
FrenchieM
Horn in hog tunes grill works may need a 1/4” spacer if using
BT brackets
Old Nov 8, 2018 | 08:58 AM
haze324's Avatar
haze324
With 8's in the bags I would consider adding horns and not dome tweeters. The Beyma SQL60 may be another option. If it were me I'd do something like a flashed radio, add a DSP, you can use the Stinger Amp to power the 6.5 and 8's, then get a small SD250.2 to power your horns.
daveblank
Audio Systems
May 2, 2019 09:28 AM
oc357
Audio Systems
14
Apr 6, 2018 08:43 AM
OUFanatic
Audio Systems
Mar 18, 2018 10:37 AM
pug3984
Audio Systems
11
Jul 12, 2017 11:17 AM
c_mancuyas8
Audio Systems
20
Jun 20, 2017 05:49 PM
