GTS Infotainment problems
Old Jan 18, 2019 | 08:30 PM
johngeorges's Avatar
johngeorges
Default GTS Infotainment problems
My new 2019 Ultra with the GTS system has intermittant problems with the radio/media. The radio will change channels and bands by itself If on 95.3 will change to 95.2 or 95.4. or scan. and change from FM to AM. When the media via USB is used will play part of the song then return to the start, Also the volume for front and rear headphones will appear on the screen even though they are not connected. These problems don't happen all the time but enough to make it annoying. The dealer has no idea how to fix it. Any theories
Old Jan 20, 2019 | 08:25 AM
Mofo67's Avatar
Mofo67
I had a similar issue. Mine would occasionally change channels and even audio source. It would also flash when riding and when it flashed you would lose sound for a second or two. Turned out to be the right hand control module. Local dealer said they had replaced 5-6 right hand control modules in past couple of months.
Good Luck
Old Jan 20, 2019 | 03:47 PM
johngeorges
Thanks so much. Ive ridden the bike 4 times and it did it twice. I'll let the dealer know
Old Jan 21, 2019 | 10:01 AM
prostar's Avatar
prostar
There is new software on Harleys site. I would try loading it and see if it fixes your issue.
Old Jan 21, 2019 | 04:57 PM
johngeorges
Could I get the dealers name and adddress thanks.
vhmike73
Jul 8, 2021 07:19 AM
flyboyron
Audio Systems
Sep 4, 2018 05:58 PM
AlanStansbery
2014-2024 Touring Models
69
Dec 18, 2014 07:58 AM
Hedgehog
30
Aug 21, 2014 08:46 PM
yokdriver
Mar 15, 2014 03:36 PM
