Wiring help
Old Mar 30, 2019 | 08:20 PM
Angryman's Avatar
Angryman
Originally Posted by SBates08
Turn the amp around. Put your RCA jacks so that they're on the right side looking at it from the front of the bike. It's much easier to get the speaker wires to fit in that tight spot versus the RCA's.
SBates, thanks. Turned the amp around and I think it will work.
Old Mar 30, 2019 | 08:21 PM
Angryman's Avatar
Angryman
Hoyt and Houston, I have some right angle RCA'S on order to try and get a little extra room.
Old Mar 30, 2019 | 08:24 PM
Angryman's Avatar
Angryman
Originally Posted by marcodarq
or you could just buy a better amp that fits the space better and have a better performing system in the end to show for it.
m
Is there a better amp at that price? Reading the forums and asking a few people in PM's that was the amp that was recommended.
Old Mar 30, 2019 | 08:25 PM
Angryman's Avatar
Angryman
Originally Posted by Hoyt 1911A1
In case turning the amp around doesn't work for you I modified a set of RCA cables to go at a straight right angle.
I just cut the plastic molding off of a set of plugs and re-soldered them as shown. Afterwards I covered them with silicone and let them dry. They cleared the frame rails fine after that.
I still have the factory head unit so I couldn't use the downward leaning amp trays like folks with aftermarket units can.
Nice work
Old Mar 31, 2019 | 01:51 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
There might be a better amp at that price somewhere in the wild but LOTS of folks here have run the SS and had good luck with it. It is powerful, built tough, and doesn't have a cooling fan to worry about going south down the road. The only reason I pulled mine out was to regain some FM reception and regain a little more space under the fairing. I had to pay a LOT more money to achieve those two goals with the Arc Moto 600.4. I'm glad I swapped it out, but I was happy with the audio performance of the SS when I had it in play.
Thanks for the compliment on the jackleg RCA connectors. It's not that I'm that good at anything, but I've been soldering since I was seven or eight years old. My Father was a radio operator in the Army in the 50s and early 60s, so in my house it was just something everyone knew how to do.
Old Mar 31, 2019 | 04:16 PM
Angryman's Avatar
Angryman
The right angle RCA's I ordered will be here tomorrow. Those along with turning the amp around like SBates suggested will solve my fit issues I believe. Now I am trying to learn how to tune / adjust the amp. From what I have read while using the search function is gains to 0, volume on radio at 75% and slowly adjust gains till distortion then back off slightly. Approximately 10-11 o-clock. Correct?
Old Apr 1, 2019 | 05:38 PM
Angryman's Avatar
Angryman
Well thanks to Amazon Prime shipping not delivering in 2 days as promised this project just got delayed a day!
Rodney Walker
Audio Systems
Mar 17, 2019 12:31 PM
cskarns
Audio Systems
Mar 9, 2019 07:34 AM
Weeboy1
Audio Systems
Feb 11, 2019 08:50 AM
Travis G
Audio Systems
Apr 1, 2018 05:09 PM
jussdandy
Audio Systems
May 4, 2013 09:08 AM
