Help with two amps
Old Mar 26, 2019 | 11:39 AM
arlington's Avatar
arlington
No doubt, once you go through the trials and tribulations of learning how to use one you can't beat it.
Old Mar 26, 2019 | 01:21 PM
Eric Steward's Avatar
Eric Steward
I want to thanks you guys for your help, like I said it sounds good now, but if I did go that route, I say again, if I did go that route I wondering how to connect it to two amps? does that make sense?
Old Mar 26, 2019 | 01:38 PM
FrenchieM's Avatar
FrenchieM
Since you asked you would use rcas to connect to the DSP from your amps.
Old Mar 26, 2019 | 02:26 PM
Eric Steward
Yes, I would. I am seeing that the Rockford DSR-1 has 8 channels. how does that play into connecting them to two amps is my question. I may be way above my head with working with both of them. Thanks,
Old Mar 26, 2019 | 02:50 PM
Tailwind's Avatar
Tailwind
Being very simplistic, a DSP gets it input from the HU typically as 2 or 4 channel input.
From the DSP to the amp/s u will have 8 channels that will feed 8 amp channels with 8 RCAs. I have the ARC PSM so I have 6 RCAs that feed 6 amp input channels. It's a very simple plug in of RCAs from DSP to Amp.
T
Old Mar 26, 2019 | 03:31 PM
Eric Steward
T
Ok, back to the pig bank. Thanks guys
Old Mar 27, 2019 | 06:51 AM
travelingypsye's Avatar
travelingypsye
Eric, keep in mind that the more "stuff" you have in the loop, the more chance of something going wrong. You have an eq on the head unit and hpf on both amps. If you have all speakers on their own channels you have the ability to tune them with the eq, gains and hpf already. With a dsp, you will have the ability to band pass each channel for the speakers but at 70 you wont be able to hear the difference. I'm not against a dsp and never ran one but from my experience, at speed all that bandpass tuning doesn't mean squat. Besides, if you start tuning for a couple of hours and think you have it just the way you want it, the next time you hear it, it just doesn't sound right so you start tweaking again and the process never ends and that would (does) drive me nuts. Rule of thumb: the less in line, the less to mess up.
Old Mar 27, 2019 | 10:54 AM
Eric Steward
That is so true. As of now, it sounds good to me.
Frisco GiantzSneaky Keaks
Audio Systems
Jan 3, 2017 11:27 AM
AGFazio
Audio Systems
Mar 3, 2016 05:45 AM
Riveroger
Audio Systems
Dec 22, 2014 12:25 PM
ImaNewbie
Audio Systems
May 17, 2012 05:56 AM
pit1600
Feb 26, 2012 07:25 AM
