Speaker Wiring
Old Apr 1, 2019 | 07:31 AM
gunslingersnation's Avatar
gunslingersnation
Default Speaker Wiring
I tried to search this out, but I think I came across everything but this. I am running a Sony a5000 hu to an NVX amp. I need to wire the amp to the speakers. Obviously, I need to change out the speaker wire to some higher grade wire. How do I do this with the pods? Do I pull the literal HD plug from the pod, and just run wire straight from amp to speaker? Photos would help if anyone has some. I tried youtube but ended up watching a 20 minute video that didnt answer the question. Install starts tonight, cross your fingers.
Old Apr 1, 2019 | 08:02 AM
Juice's Avatar
Juice
Pull the plug, put a slice through the grommet to the wire and remove the stock wire.
Ream it out carefully with a drill bit bigger than the stock wire and put new wire through it.
Juice
Old Apr 1, 2019 | 08:03 AM
Tailwind's Avatar
Tailwind
You can just pull that plug and speaker terminals out and use the same grommet and hole to run the new wire.
T
Old Apr 1, 2019 | 08:25 AM
gunslingersnation
Sweet, so just a razor knife to split one half of the gromet and run heavier gage. Thanks guys!
Old Apr 1, 2019 | 10:53 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I feel lazy now. I just left the factory wire in the pod underneath some polyfil and ran my new wire through the grommet. I did use zip ties to secure it to the factory wire though where it ran along the frame rail. I guess that means I am still using the factory wire to some degree.
Chucks1911
Audio Systems
May 4, 2018 07:20 AM
KSGLIDEGUY
Audio Systems
36
Mar 1, 2018 12:52 PM
robert.schoelkopf@gmail.com
Audio Systems
Oct 30, 2015 10:21 AM
uwiik
Audio Systems
Nov 6, 2013 10:00 PM
SD2010FXDWG
Oct 11, 2013 08:53 PM
