Amp Voltage question
Old Apr 9, 2019 | 06:50 PM
Eric Steward's Avatar
Eric Steward
Default Amp Voltage question
My setup,
Sony AVX-AV100 HU output is front channels are connected to the Arc and the rear channels connected to the NVX VAD 1000.4 , Arc 600.4 in the fairing running the ,Arc 6.5 602's Upper and lower fairing with JL C2-650 6.5 in the TP wired in parallel with the lower fair on the front channels on the Arc. The NVX VAd 1000.4 is running the JL audio 6x9 (c2-690-xt) in lids and inside of bags. the lids are connected to the front channel on the amp and the 6x9 in the bags are connected to the rear channels on the amp.
I connected my DD-1 to set the gains on the amps i'm running. I was able to do it on the Arc with no problems, but when I tried to do the NVX it was distorted before I even moved the gains ( at zero ) 40 hz and 1khz. the specs for the amp calls for a 4 gauge power and ground wires, but that wire seams huge for a motorcycle and a 100 amp fuse. Is this over kill for this amp on a bike. RMS is 1000?
Old Apr 9, 2019 | 07:29 PM
Babyboy's Avatar
Babyboy
Originally Posted by Eric Steward
My setup,
For starters the Arc 600.4 is going to be light on power to drive a set of 602s and the JL c2s as the are both lower efficiency speakers and the 600.4 is 150 watts at 2 or 4 ohm. Both of those speakers will require around 150 to get into their happy place.
As for the distortion coming out of the NVX I would check the input signal to the amp and make sure you have a clean input signal. If the signal is distorted recheck the RCA cable and make sure it isnt bad
Old Apr 9, 2019 | 08:06 PM
Eric Steward
I didn't think of that, thank you.
Old Apr 9, 2019 | 08:56 PM
marcodarq's Avatar
marcodarq
You should not even use a 40hz test tone, unless you have speakers that can handle that frequency. What are yor crossover points and how eq are you using throught the Hu?
M
Old Apr 9, 2019 | 09:50 PM
Eric Steward
M
EQ is off. I did notice that when I connected my rear RCA cable to the front RCA Jack on the HU I was able to set the gains. But when I used another RCA cable from the HU rear output to the amp, I got the distortion. I think the rear RCA jack on the HU is not putting out a clean signal. Any thoughts?
Old Apr 10, 2019 | 11:31 AM
Sturgis67's Avatar
Sturgis67
If your power wire is near your signal RCA wire that can cause some noise issues.
Old Apr 10, 2019 | 12:56 PM
Eric Steward
No, because I ran another RCA wire around the whole bike in the outside.
Old Apr 10, 2019 | 03:23 PM
marcodarq's Avatar
marcodarq
did you try the same cable on front and rear HU outputs and get different results, that would point to an issue with head unit or settings. if the same cable gives clean signal on the front output but not on the rear, the cable is most likely good, and an issue in the HU. try sending signal front front outputs, to rear amp and see if its clean, to confirm the rca cable.
if you can not return the HU, you could try to use a Y splitter, to feed all amps, but you'dll lose fade.
m
Old Apr 10, 2019 | 05:28 PM
Eric Steward
m
Yeah it was clean,thanks. The front to the rear amp was fine,GUESS the HU rear output is bad
Stew_FL
Audio Systems
16
Apr 22, 2018 10:12 PM
RWood
Audio Systems
11
May 23, 2016 01:51 PM
Eshaw301
Audio Systems
Apr 25, 2014 03:06 PM
mphillips21
Audio Systems
Aug 29, 2013 12:12 PM
1sweetglide08
Audio Systems
Jun 25, 2013 05:24 PM
