So I’m down to wiring my bike. Have had lots of suggestions given on the way I should do it. Appreciate everyone’s help! Made a couple rudimentary schematics and wanted to groups input to make sure I don’t blow anything up. Lol
my system again;
sony dsxs310btx
SD800.4
SD400.4
fairing
prv 6.5 neo
vo-b3
lids
vo 6x9
st-25
questions
1) if I run the horns in parallel due I just need one capacitor per set or one per horn?
2) do I have the x-overs set right on the maps?
3) what about gain settings?
4) rca’s. Radio has 4 outputs. LF/RF/LR/RR. I assume I just run splitters off each output to run both amps? Wasn’t sure if I need 4 channels fed when I bridge SD400.
Thanks for everyones help. I’ve really learned a lot for you guys!
