Audio issues
Old May 1, 2019 | 12:55 PM
Jae Will Bee's Avatar
Jae Will Bee
6th Gear
Cool I’ll look into the alternator because the battery is new
Old May 1, 2019 | 01:51 PM
marcodarq's Avatar
marcodarq
quick and dirty test with a DMM, check what your voltage at the battery while the issue is occuring, you will see the voltage drop if the amp is drawing too much current.(may drop below 12 volts, if so that's an indicator) if so, then you move on to amperage testing.
m
Old May 1, 2019 | 01:52 PM
Jae Will Bee
6th Gear
Will do I appreciate the advice from you all
Old May 1, 2019 | 02:07 PM
Tailwind's Avatar
Tailwind
Turn ur gains on the amp down a couple clicks and give it another try.
T
Old May 1, 2019 | 02:13 PM
Jae Will Bee
6th Gear
This particular amp has no gain control
Old May 1, 2019 | 02:18 PM
Tailwind's Avatar
Tailwind
My bad. Sorry.
T
SoloRider67
Mar 23, 2018 08:08 PM
FireHogRider
Electrical/Lighting/Alarm
Apr 6, 2015 09:38 PM
livinfree
May 18, 2014 09:11 AM
bucknit21
Apr 14, 2013 09:43 AM
RidemyEVO
May 30, 2010 10:53 PM
