BT Bracket Work Around
Old May 5, 2019 | 12:59 PM
Tailwind's Avatar
Tailwind
Originally Posted by gunslingersnation
Obviously, I am not questioning your knowledge. I just can't see how it could be misaligned. The holes are all predrilled to match. There didn't seem to be any oblong holes to allow for adjustment.
If u have a 1/2" difference in where the left vs right brackets sit then there really is no other explanation.
T
Old May 5, 2019 | 03:38 PM
gunslingersnation's Avatar
gunslingersnation
So I took the clutch side off, left all the bolts loose, and I could not find a position that worked. It's almost like the fold angle isn't quite the same, but I'm sure the same machine is progammed to do the same work. I ended up taking the aluminum piece off and I'll mill it a 1/4" or so. That's the only thing I can think of to keep the security and the hole angle.
Old May 5, 2019 | 04:18 PM
marshallb's Avatar
marshallb
Personally I wouldn't go mlling on it until I knew what is going on. It's not easy to put aluminum back on.
Old May 5, 2019 | 08:48 PM
Tailwind's Avatar
Tailwind
Yup!!! Never once have I heard that a BT bracket has not lined up properly. I would not start hacking on it until u have had the extreme patience to truly identify what is going on with that entire fairing.
T
Old May 6, 2019 | 11:21 AM
gunslingersnation
So I just got off the phone with Biketronics...very nice people. Cindy was able to tell me that the clutch side uses a different aluminum structure piece than the brake side. Mine had accidentally been shipped with two of the same. She is putting a new standard in the mail, along with the bolts I broke. Good service is hard to find, so I am thrilled.
Weavr99FLHT
Feb 12, 2014 09:04 AM
Terrabella
Jul 22, 2011 10:08 PM
Our07Ultra
Apr 24, 2010 01:56 PM
CURTYS06FLHX
Mar 26, 2010 09:26 AM
electra glide
Feb 23, 2009 10:56 AM
