is the 2v preamp output enough on the Sony XAV-AX5000?
Old Jun 25, 2019 | 09:13 PM
dabears1985's Avatar
dabears1985
Originally Posted by eggwhite93
Thanks for getting us back on track BP. Although Brazilian midget strippers are intriguing.
So, could I improve my sound/volume if I were to boost the voltage going into my amp?
The stronger the pre-amp signal the less the amplifier has to work(less turn of the gain ****). So you should notice less hum/hiss thru your speakers with no volume and probably a cleaner sound parked. The difference on a bike going down the road though is probably negligible but you would have to try it to know for sure. A 2VAC pre-amp should be able to drive the vast majority of amplifiers to full power without clipping prematurely so overall system volume probably wouldn't improve. If you look at the specs for your amp it should tell you the input voltage range.
Old Jun 25, 2019 | 09:17 PM
dabears1985
Originally Posted by BlackPearl#1
Is a DSP capable of doing what the OP I interested in?
My DSR-1 does. I have the AX5000 as well and the output from the DSR-1 to my amps is about 5VAC on all 8 channels. I will check the DSi-2 when I install sometime in the next week or so.
falconbrother
EVO
33
Aug 20, 2023 07:55 AM
rain rider
Audio Systems
Jun 27, 2018 06:43 PM
ericl
Audio Systems
Jun 9, 2016 12:09 PM
slyedog
Audio Systems
May 9, 2016 09:45 AM
sonnydaze
Jul 16, 2013 03:38 PM
