CV B52 died
Old Aug 4, 2019 | 07:34 PM
roussfam's Avatar
roussfam
Default CV B52 died
Was working fine, then it wasn't. All connections etc. are good. Amp is getting turn on signal from head unit. Just wont power up. Anybody else experience this?
Jim
Old Aug 4, 2019 | 07:41 PM
SG-Jay's Avatar
SG-Jay
Did you check for power at the amp? Maybe you blew a fuse?
Old Aug 4, 2019 | 07:45 PM
roussfam's Avatar
roussfam
Fuses are good, power at the amp, good ground. little switch in the back is set to remote start
Old Aug 4, 2019 | 08:09 PM
GunslingersNation1's Avatar
GunslingersNation1
I have one laying around if interested.
Old Aug 4, 2019 | 09:59 PM
langwilliams's Avatar
langwilliams
I've had mine in the bike for about a year an I think it's going bad. Sound will cut out for a few seconds then come back. Both speakers go at the same time an the radio display never changes. I pulled the outter an checked all the connections an they were good. I rode on some really hot days this year an earlier this year the ground worked loose....I'm thinking it's going into protect mode an it might be damaged from the heat or loose ground. I'm thinking about the NVX for around 170. I'm thinking I'll add a cooling fan when I replace the CV amp.
Old Aug 4, 2019 | 10:56 PM
eggwhite93's Avatar
eggwhite93
Are you using the AVC?
Old Aug 5, 2019 | 07:41 AM
roussfam's Avatar
roussfam
Yes, have been since install. No problems. With the bike off, switched to accessories, head unit on, amp will not turn on and no sound to speakers. Remove amp from equation, sound plays fine.
Jim
Old Aug 5, 2019 | 08:11 AM
eggwhite93's Avatar
eggwhite93
Jim
You are going to need a new amp. Do not use AVC! I (my wife) killed a B52 the same way.
Old Aug 5, 2019 | 03:34 PM
roussfam's Avatar
roussfam
Wether I turn the volume up and down according to my speed or the bike does it for me, can't see what difference it would make. My vehicle came with a premium sound system and a 240 watt amp, the volume varies according to speed from the factory.
Old Aug 5, 2019 | 03:40 PM
SBates08's Avatar
SBates08
What year bike is this on?
