Music or underwear?
Old Aug 17, 2019 | 09:19 AM
CaffeineBuzz's Avatar
CaffeineBuzz
You know you're learning when the answers to questions lead to new questions.
My biggest takeaway is to be patient.
I don't want to release any magic smoke. Juice says all the parts work way better if the magic smoke stays in the parts.
I'm anxious to start doing something, especially after hearing Juce's rig.
Old Aug 17, 2019 | 09:38 AM
Bluesman280's Avatar
Bluesman280
Definitely sounds like you are in good hands.
Take your time. Pick your gear wisely. Take your time on the install, and you should be rocking before you know it. $2500 sounds like a more than adequate budget to get it done right the first time.
Old Aug 17, 2019 | 10:29 AM
Geezer Glide Bob's Avatar
Geezer Glide Bob
My electronics professor in collage would say FM does not stand for "Frequency Modulation" but fricken magic. Once you let the FM out of the electronics there done!
Use a fuse and you should be fine. Just use a fuse for the correct amps that will blow before the eqt...
YOU ARE IN GOOD HANDS....
You are learning GRASSHOPPER!!!!!
Eric Steward
Audio Systems
Aug 16, 2019 03:21 PM
08FXDL
Audio Systems
Dec 26, 2018 04:27 PM
mmats69
Audio Systems
Feb 25, 2017 06:28 PM
Grizz72
Audio Systems
Jan 25, 2017 10:15 AM
Licopico
Audio Systems
Mar 11, 2016 02:44 AM
