Tuning with a DSP????
Old Aug 22, 2019 | 06:53 PM
cskarns's Avatar
cskarns
Default Tuning with a DSP????
I recently installed a Dayton DSP in my old 1988 Ultra. It really helped improve the sound of the system. I want to make sure I have things set correct before I continue to tinker with the DSP settings.
Do all the settings on the HU EQ need to be set flat and all the crossover frequencies set to through?
Does the amp needs to be set at full pass?
Now, do I adjust the DSP settings then the gains on the amp or the other way around?
Thanks Chad.
Old Aug 24, 2019 | 10:12 AM
Budda109's Avatar
Budda109
Yes and yes. As far as the gains I adjusted them with the DSR flat. After I tweaked the EQ I was able to turn them up a bit. Mostly because some of the freq's were not as harsh.
GoatHD
Audio Systems
13
Aug 15, 2017 08:46 AM
Hades02
Audio Systems
Aug 13, 2017 04:52 PM
SgtMic
Audio Systems
Mar 13, 2017 07:26 PM
NorthEnd
Audio Systems
Mar 22, 2016 04:30 PM
MJR
Dec 9, 2007 12:06 AM
