Another dumb question: Do you give up control resolution on the volume by setting the amp gain for 75% of source volume? Or, asking that another way, can the radio still be turned all the way up?
If max gains are set at 3/4 volume than that is your new max for volume. Can you turn it up sure
but be prepared for distortion or magic smoke eventually
When you set your HU at 75% and set your gains to that.....75% is now your WOV (wide open volume). Do not go past that point.
In the interest of protecting the system, wouldn't it make more sense to either use 100% of source output volume or decrease the target voltage to 75% when setting the gain?
Or, is setting the gain at 75% of source volume an exercise with sound quality as the goal?
Hopefully no one is getting too frustrated by these questions. Just trying to understand what the ultimate goal is for setting an amp up this way.
Your using 75% volume on the head unit as a max because it's usually a safe bet that you'll have a clean output signal into the amp. You don't want to amplify a distorted signal. If you set your gains with the volume at 100% that's exactly what you'll be doing
