JL VX8008i
Old Sep 12, 2019 | 09:55 PM
scumBAGGER's Avatar
scumBAGGER
Default JL VX8008i
Anyone here running the JL VX800\8i? how did you mount it or better yet where did you mount it?
Old Sep 12, 2019 | 10:17 PM
Stuntmeat's Avatar
Stuntmeat
I mounted it in the fairing. But you must use the j&m amp tray. This is on a 17 street glide. Not sure on a pre-Rushmore. There’s one other person on here that I know is running it.
Old Sep 12, 2019 | 10:28 PM
scumBAGGER's Avatar
scumBAGGER
sweet you got it under the fairing? I have a 19SG and switching things up and I just found this amp I like the specs and it looks like it will be a great fit for my build
you have pics? does the j&M try put the amp above the radio?
Old Sep 13, 2019 | 12:21 PM
Stuntmeat's Avatar
Stuntmeat
Sorry no pics. But if you search for member here Ron D 33. He has posted some pics of his setup with the jl amp on the j&m amp tray. Yes it puts the amp on top of the radio.
Old Sep 13, 2019 | 01:07 PM
InthewindMN's Avatar
InthewindMN
https://www.hdforums.com/forum/audio...h-the-new.html
Old Sep 13, 2019 | 06:29 PM
Ron D 33's Avatar
Ron D 33
Andy is correct that it'll fit. It's a nice amp and I'm sure Andy agrees, but it's pricey. Jim posted a good thread for info on it. I've had it in since the install and don't plan on pulling it out. I usually don't keep stuff on long either and it's standing strong.
Old Sep 15, 2019 | 11:59 PM
scumBAGGER's Avatar
scumBAGGER
Thanks guys...
Ron,
what is the pass though 2 channels? I see you added a second amp is that amp running your faring speakers?
I'm coming up short on channels the jl amp will be running a set GZ yellow basket 8 bridged on 2 channels then a set prv gmr500 ndy in the lowers off one channel but here is where I'm stuck looking at another set of Prvs for the faring and set of super tweets But I only have one channel left on the JL. not sure if just adding a second amp for the Super tweets is the route to go?
Old Sep 16, 2019 | 06:23 AM
Stuntmeat's Avatar
Stuntmeat
The pass through channels are an output to an additional amp that can utilize the crossover and dsp portion of the JL is on.
Old Sep 16, 2019 | 06:54 AM
Ron D 33's Avatar
Ron D 33
Originally Posted by scumBAGGER
Thanks guys...
Ron,
It's just like Andy said and a pass thru that uses the TuN program. I have two NVX VADM2 in the cubbie that go thru it. Each one is bridged to a side running a set of 8 ohm 6.5" speakers in the lids.
Lethal Weapon
Touring Parts
14
Aug 21, 2019 08:07 AM
Bodacious MC
Jul 25, 2016 09:44 PM
William C
Oct 2, 2014 09:41 AM
dfowler1
Touring Parts
Jul 21, 2014 09:41 AM
RadioBob
General Topics/Tech Tips
Dec 14, 2012 10:06 AM
