Fosgate t400x2ad Trouble
Old Oct 11, 2019 | 06:29 PM
2017M8's Avatar
2017M8
Are the amp Gain (s) at the 11-1 position?,,,
Old Oct 11, 2019 | 07:37 PM
eggwhite93's Avatar
eggwhite93
It’s probably not the problem but the amp should be grounded to the battery.
Old Oct 11, 2019 | 07:58 PM
Tailwind's Avatar
Tailwind
My amps are grounded to the grounding post just in front of the battery and they seem to work ok.
T
Old Oct 11, 2019 | 08:00 PM
Tailwind's Avatar
Tailwind
Originally Posted by BurpleHugger
I am trying to install a t400x2ad I got and I can't get any sound. Power light is lit up. I'm only swapping out amps and my system worked just fine. Playing from an aux chord to Y rca's. Everything is connected correctly but I can't get the green clip light to come on when setting it up. Any tips on what and how I should test? i'm not too well versed in testing amps.
$5 says ur amp is not getting an input signal aka phone or accessory wiring going into the amp.
T
Old Oct 14, 2019 | 11:38 AM
BurpleHugger's Avatar
BurpleHugger
Originally Posted by firemedic4500
Make sure your remote wire is hooked to a good 12v source that is on ignition such as your cig lighter.
NAILED it. All is working well. Appreciate the help.
Old Oct 14, 2019 | 11:40 AM
BurpleHugger
T
I'll take that bet lol. It was the remote wire. Thanks for the help!
Old Oct 14, 2019 | 12:52 PM
teedoff65's Avatar
teedoff65
Isnt it the same thing? The accessory wiring IS the remote wire?? lol
fatfatboy
Apr 12, 2015 01:22 AM
jcain
Audio Systems
14
Mar 18, 2014 05:07 PM
01 springer
Jun 5, 2009 11:23 AM
BadPiggy
Oct 31, 2008 09:20 PM
mnbagger
Apr 15, 2008 07:45 AM
