8" Options
Old Nov 5, 2019 | 02:31 PM
boosted20v's Avatar
boosted20v
Default 8" Options
First off let me start by saying I blame you Tailwind! LOL.
It's time to add some sound to the back of my sled. I've been going back and forth on 6x9/7x10's in the lids but I think I'm coming around to 8's in Advan Black Lids, ( I like the idea of 2 8's in a TP but don't want to go through the hassle and expense of having someone color match it), besides I already have the Advan Black side covers and bags so it makes sense.
Losing bag space is not an option so anything in the bags is out. I'm really looking to get that full sound with as much mid/bass as I can get out of lids.
Now my current set up is a pair of MMats 601cx's in the fairing mated to a Diamond Micro 2v2 via a Sony 5000, no DSP and I really like this set up so looking for 8's and probably horns that will stand up to the occasional rain storm (I'm a very fair weather rider but hey it happens) and pair well with my current set up. I have a TX48 sitting on the bench in my garage just waiting to be used.
Do I go the MMats PA801 route? Diamond weatherproof HXM8's? Via reading a bunch of threads doing a search I ran across some mention of Rockville RM84's that sounded intriguing and when I looked them up at $34 they are even more intriguing!
What horns should I be thinking about, and how should I approach powering everything using the Diamond, and the Massive TX48(I'll plan on adding a DSP as well?
Thanks in advance!
Old Nov 5, 2019 | 02:54 PM
cshocker's Avatar
cshocker
Use the Massive to run 6.5's and 8's. Diamond for horns (if you don't go with a full range 8"). So if you go with a full range, you could get by with 1 amp. But then you're also limited on options for full range 8's (Mmats, DB drive, Diamonds).
If you want to run horns and second amp, there are a lot of 8" mid bass/mid range options (PRV, Rockville, GZ, Hertz, Beyma, etc). But you may run into a power problem because some of those don't kick in till over 200 watts.
Take your time and plan it out accordingly. All depends on what your looking for.
FYI: the Mmats 801 px are a great sounding full range speaker that doesn't require a lot of power and marine grade. And also, plan on spending some money on grills. Don't go all the way with adding 8" lids and get some cheap *** grills.
Old Nov 5, 2019 | 04:05 PM
boosted20v's Avatar
boosted20v
This is a must!
Old Nov 5, 2019 | 04:07 PM
SBates08's Avatar
SBates08
If you go 8ohm on your 8's you can parallel bridge them to the rear channels on the TX48. 400 watts to each lid would be awesome.
Old Nov 5, 2019 | 04:50 PM
Adenton528's Avatar
Adenton528
Deleted
Old Nov 5, 2019 | 04:58 PM
Tailwind's Avatar
Tailwind
I think Mmats is claiming their sled horns are weather friendly.
T
Old Nov 5, 2019 | 05:06 PM
boosted20v's Avatar
boosted20v
Originally Posted by Adenton528
Agreed here. Look at the GZ yellow basket 8. Strong bass in an 8 and 400 should make them pound. Add a good solid horn and let it eat.
Are they occasional weather friendly? LOL
Old Nov 5, 2019 | 05:57 PM
ScreamingSkulls's Avatar
ScreamingSkulls
Listen to this man. His suggestion is what I did with PRV 8s in the bags off the rear channel bridged on the TX48 and they pound.
Old Nov 5, 2019 | 06:21 PM
InthewindMN's Avatar
InthewindMN
There are several mid bass speakers for 8” lids. The problem is that many of them don’t really play as low as we would like. Determine budget, goals and available power and go from there.
Old Nov 5, 2019 | 06:22 PM
SBates08's Avatar
SBates08
Spray them with Camp Dry or Never Wet. Good to go!!!
