Need Help with Audio System Purchase
I have someone to do the install but I need to know exactly what to purchase. So far I've come up with the following but not sure of a few options? Sorry, but I'm very new to this stuff and don't want to show up for an install and have the wrong items.
1 - Stinger SPX700X4 Micro 4 Channel 700 Watt Ampifier
4 - MMats Pro Audio PA601.cx 6.5" Pro Coax (not sure which ones 4ohm or 8ohm)
2 - BT355 HD Radio LIne Leveler and Pre-Amp Adapter for 2014 and up (options available? front speaker connection? Street/Classic/Road In-Fairing Rear Speaker Connector (ex. Ultra and CVO)?, or Universal?)
VTwin tour pack speaker adapters (not sure what to get here? and how many?)
Go with 4 ohm speakers
Since it's an ultra, your options are
1. BT Breakout Harness with Line Levelers - This will retain fade and is the more expensive option
2. BT355 with Front Speaker connections only and use Y adapters to the amp for front and rear. Basically, front will be left and rear will be right, or vice versa. This is the less expensive option but does NOT retain fade
For the Tour Pack spacers, go to VTwinaudio.com and search for 14-up tour pack pods.
If you wouldn't mind checking out these links to confirm what I'm about to order it would be muchly appreciated. I just don't know enough about this stuff I would hate to take the bike in for the install and end up not having something.
Stinger Amp
4 of these MMats Pro Audio PA601.cx (4ohms, water proof, 6.5" ring and grill with badge)
https://www.mmatsproaudio.com/site/product/pa601cx/
BT Breakout Harness
http://www.biketronics.com/rushmore-...-n-play-btboc/
Tour Pack Pods
https://vtwinaudio.com/product/v-twi...r-pod-adapter/
Is there anything else? Wiring Harness etc?
Thank you so much,
Brian
I guess I have an amp for sale now. Ugh
