2019 electra glide standard
Old Feb 26, 2020 | 04:06 PM
Patrick Raygor's Avatar
Patrick Raygor
Stage II
Default 2019 electra glide standard
So i have a 19 EGS and I purchased the 4.3 boom audio for it along with boom stage 1 speakers. After the hassle of figuring out all the extra crap I needed. It is all installed. But now I'm finding out I cannot adjust the volume without hand controls??!! Anyone know of this issue or if it's possible without. And if not is there any cheaper easier options to adjust the volume.? Like wiring in just a **** for that feature or were to find just that button to add?. Thanks.
Old Mar 28, 2020 | 05:51 PM
PeanutUSMC's Avatar
PeanutUSMC
I also have a 2019 EGS but I installed a Sony 5000 head unit kit. You should be able to purchase the lighted handlebar control set, then you should be able to control the HD boom radio. The controls cost about $200 and should just plug in. Hope this helps.
Old Mar 28, 2020 | 05:53 PM
PeanutUSMC's Avatar
PeanutUSMC
Forgot to mention that the lighted controls are available at HD.
Old Jul 21, 2020 | 03:35 PM
engscott78's Avatar
engscott78
Well hell, so much for that upgrade. I just ordered the AX7000 plug and play through Fat Head. It was cheap enough.
Old Dec 16, 2020 | 07:14 PM
Jordan10's Avatar
Jordan10
2nd Gear
Did you end up figuring a solution out? I want to instal the 4.3 ask but not the volume switch as I have 14 in crow bars on it and they are a hassle to pull through. Can you adjust volume with your phone through Bluetooth?
kazanimo
Sep 19, 2019 04:50 PM
howie54
Audio Systems
Aug 1, 2018 04:59 AM
Phil George
Jul 12, 2012 09:14 PM
Fluffy110
Mar 28, 2012 10:04 PM
JustDennis
Aug 26, 2008 09:50 PM
