4.3 to 6.5 Upgrade
Old Mar 2, 2020 | 10:36 AM
hooper1668's Avatar
hooper1668
Default 4.3 to 6.5 Upgrade
I have read so many posts that I do not know what questions to ask. Thanks to all who respond. It is much appreciated. I have a 2016 Street Glide with the 4.3 system. I only have the two front fairing speakers. I have the handlebar controls. (Not sure if all have these so I thought I would add this) All I want to do is swap out the 4.3 for a 6.5 so I can have the GPS and SiriusXMradio and use the handlebar controls.
Can I just swap out the head units and be done? After reading about wiring harness, amps, line levelers, install and flash it on a 2019 model first, etc I have no clue what to do. I do not want to spend extra dollars for nothing.
I also wanted to ask why so many are taking the 6.5 off and replacing it with aftermarket models? Is it better to just go get the Sony 7000 (which seems to be the favorite right now?) or perhaps another model? Just curious.
Thanks in advance
Respectfully,
Will
Old Mar 5, 2020 | 11:04 AM
Juice's Avatar
Juice
Simple answer is yes you can. Depending on what bike the 6.5 unit will come out of will determine if you need it flashed or not.
Juice
Old Mar 5, 2020 | 06:07 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hooper as far as swapping out to a non Harley head unit keep in mind that you will lose the weather resistance and several other Harley specific features. Also the Sony does not have built in navigation that runs off of satellites, you would have to rely on cell service for nav.
GooseWaffles
Audio Systems
Aug 16, 2024 04:46 PM
Eyeball Kid
Audio Systems
Sep 12, 2013 11:01 AM
jkaylor
Audio Systems
Apr 9, 2013 12:10 PM
lanceheller
Audio Systems
Sep 25, 2012 02:49 PM
PistonPuller
Jun 21, 2011 06:44 AM
