DSP USB Connection Inside Fairing
Old Mar 16, 2020 | 07:56 PM
Evil Eye's Avatar
Evil Eye
Originally Posted by Dhellyer
I used this bulkhead USB connector in place of the cigarette lighter. Works great.
https://www.amazon.com/dp/B01N6ERRX7...p_mob_ap_share
Yes, this is a fantastic idea and exactly what I was thinking. Thanks brother!
Originally Posted by gerby151
Another suggestion is to switch locations of your tweets and gauges to get them higher in the fairing. It does make a difference in sound IMHO
Randy
Interesting. So swap the place for the batter voltage and fuel meters for the tweets? I'm definitely up for considering that. When I open the fairing back up this weekend, I'll give it a shot and see how it sounds. Thanks for the advice!
Originally Posted by F6Pilot
I am assuming you cannot use the Dayton USB bluetooth dongle due to the length causing it to protrude too far. You could alternatively use a short USB extension cable and just lay the bluetooth dongle anywhere inside the fairing.
https://www.amazon.com/C2G-52119-USB.../dp/B00CJG2ZYM
Yes sir. I had a BUNCH of disconnects with my RF DSR1, so I'm concerned that I'll have similar issues with bluetooth. Are you using it and how has it worked out?
Old Mar 16, 2020 | 08:41 PM
Checkmate23's Avatar
Checkmate23
I have the Dayton, and the Bluetooth. Zero issues.
Old Mar 16, 2020 | 09:07 PM
F6Pilot's Avatar
F6Pilot
I have not personally used the Dayton Bluetooth yet but plan to. I know several who have used it successfully. The bulkhead connector option is also a great idea, providing a direct connection to the source.
Old Mar 17, 2020 | 09:47 AM
boosted20v's Avatar
boosted20v
The Dayton Bluetooth dongle works great, I've had no issues with it. Probably cheaper than all of the other solutions you're looking into as well. Using a USB extension may not work though. Tried one on an install with my buddies DSR and it would not recognize the dongle.
Old Mar 17, 2020 | 04:30 PM
GunslingersNation1's Avatar
GunslingersNation1
This is what I just did, although it's to keep a connection to the xav-ax5000 2nd usb port, which is used for firmware updates. It may work for your needs. $10 on Amazon.
Old Mar 18, 2020 | 05:57 PM
Evil Eye's Avatar
Evil Eye
Thanks, everyone! I think I'll give the bulkhead USB connector a shot and go from there. I'm already going to have to pull the outer fairing again to re-run some wiring and chase down what I think is a floating/bad ground, so I'll put this in at the same time. My new system sounds FANTASTIC and I'm extremely grateful for the folks who have shared their ear, advice and expertise. Adenton, Tailwind, Outkast, gerby and several others on this forum. Hell, you can see it in this very thread! So, thank YOU for chiming in and making this forum an excellent resource and willingly sharing your experience with me.
dennyo
Jan 16, 2018 07:14 PM
gartec81
Nov 15, 2017 12:33 PM
TomboAT65
2014-2024 Touring Models
26
Feb 27, 2016 10:00 PM
mrsnipy
Apr 20, 2012 05:21 PM
BadPiggy
Feb 10, 2009 05:50 PM
