disproportionate Volume Increase
Old Mar 21, 2020 | 05:21 AM
Jpm1416's Avatar
Jpm1416
Default disproportionate Volume Increase
I installed PA601cx's with a Stinger 700.4 running a Kenwood kmm-bt225u head unit. I have the gains set maybe a little on the conservative side at pushing about 100 watts to the speakers.
As I turn up the volume the audible increase doesn't seem proportioned, when I get to probably 70% of the total volume range the sound increase is very rapid. Any I ideas how to get the actual sound output to be more proportioned across the volume range?
Old Mar 21, 2020 | 05:45 AM
bustert's Avatar
bustert
i am assuming everything is a factory (not meaning hd) setup. if so, not much you can do without going to component level. i also assume the units are logarithmic and not linear pots. there is one trick and that is to add a load resistor circuit to the pot, usually a very small value, this will alter the curve.
Old Mar 21, 2020 | 06:55 AM
Babyboy's Avatar
Babyboy
Some of the aftermarket Kenwood headunits have a gradual increase in volume as they should until you get to around 30 on the volume numbers. Then they do increase the output voltage from 30 and up causing the volume to raise faster.
It is just the way the manufacturer has made them so what you are hearing is normal.
Old Mar 21, 2020 | 04:56 PM
USAproud's Avatar
USAproud
Yup, had a huge increase in output voltage over 30. every click after is a bigger jump than you think
Old Mar 21, 2020 | 08:57 PM
Tailwind's Avatar
Tailwind
Make ur self inflicted max volume 29 and set the gains according to that so that u get a linear increase in volts/volume all the way up to that point?
T
adehagen
Audio Systems
Jul 26, 2019 05:13 PM
usmcdevildog
Oct 20, 2018 08:21 AM
Tn.Heritage
2014-2024 Touring Models
15
Mar 15, 2016 11:46 AM
ChristoHD
Mar 15, 2011 05:58 PM
vtxed
Mar 18, 2007 07:31 PM
