Need some help, I'm at a loss
Old Apr 17, 2020 | 12:39 PM
Babyboy's Avatar
Babyboy
I just set up a SD800.4 EVOX 4 ohm last night.
The max clean signal using a 1k 0 db test tone , 4ohm dummy load, 13.4volts dc input and a oscope was 24 acv on the output.
As others have mentioned you need to verify the settings on the DSP in use. To high of an output voltage from the DSP will cause a clip at low headunit volume
Old Apr 22, 2020 | 11:46 PM
glock221's Avatar
glock221
Figured it out. stock head unit had the factory 2020 RG Limited flash in it.
Flashed it to Rockford with techno tool and it cleaned everything right up. Was able to go slightly above half gain and no more clipping.
Interesting point was from the head unit the SD EVO 800.4 2 ohm was on front channel powering the 4 red baskets no clipping no issues. The 800.4 EVOX 4 ohm was was on the rear channel, standard 4 channel wiring, 2 horns on 1&2 and the DA Coax subs (6x9) on 3-4. Now it sounds great. Pushing about 132 watts to the DA's. I think 200 would really wake them up, but I am done for now.
Thanks for the input.
Old Nov 14, 2020 | 07:59 PM
GeezerGLD's Avatar
GeezerGLD
Do you happen to remember closely where you gains were at, at that voltage or maybe a pic. Curious on the x over also. Seems after 80 it’s a crap shoot.
Old Nov 14, 2020 | 09:17 PM
Babyboy's Avatar
Babyboy
The gain position will very on any and all systems when setting them up because there is no 1 input voltage that is the same.
I have found when setting up a system before any speakers are even hooked up that there is always a voltage difference from channel to channel. Granted it may only be .5 volts but I have seen them as high as 2.5 volts different between channels on the output of an amp.
(Typical with electronics.)
I would HIGHLY RECOMMEND getting your meter out and setting the gains as per the sticky on the first page as there are to many variables from system to system.
Old Nov 14, 2020 | 09:48 PM
FrenchieM's Avatar
FrenchieM
As was stated in your other post it varies as Babyboy said. Gain pots on SD are touchy to begin with. Use your meter and be satisfied with that no if not get it to a tuner with a RTA and some knowledge of a dsp
mstng5point0
Audio Systems
Dec 14, 2016 08:35 PM
rvjam
Audio Systems
Mar 10, 2016 10:25 AM
13SGERS
Audio Systems
Mar 24, 2014 06:14 AM
gjcusa
Audio Systems
Jan 3, 2014 12:01 PM
scumBAGGER
Audio Systems
14
Mar 29, 2013 09:10 AM
