Amp Install Questions
Old Apr 18, 2020 | 04:49 PM
spidermo's Avatar
spidermo
Default Amp Install Questions
I am planning out my amp installation project, which will consist of (2) two amps powering (6) six speakers. Anyone have issues with mounting power and ground blocks on Biketronics speaker brackets. I would like to mount power centric stuff on throttle side of fairing and amp/line-levers on opposite side.A Stinger spx700x4 will power mains and a kenwood 400 watt amp will power the lower pods. I am open to suggestions for an alternate micro amp for lowers.
Old Apr 18, 2020 | 05:19 PM
Fireball Jack's Avatar
Fireball Jack
You probably give a bit more info. Bike, deck, speakers and location.
Old Apr 18, 2020 | 05:23 PM
spidermo's Avatar
spidermo
2016 FLHTK w/speakers in fairing, lowers and tourpak
Currently installed: GTS head unit
Hogtunes (6) speaker plus amp setup
Planned installation: Biketronic breakout wireharness
Stinger SPX700 amp
Kenwood KAC M1814 amp
(2) Biketronic line levers
Speakers are currently Hogtunes add on's. I do plan on swapping out after Sturgis trip.
Old Apr 18, 2020 | 05:52 PM
Dsm Limited's Avatar
Dsm Limited
Are you pregnant with any of your list?
Old Apr 18, 2020 | 06:45 PM
Fireball Jack
I would do without the Break out harness. I have not used my fader unless I am tuning. Ditch the Kenwood amp. Get rhe Stinger and a NVX VDAM4 and with the money you save on the harness get a set of speakers. I am sure there are better options.
Old Apr 18, 2020 | 07:22 PM
spidermo's Avatar
spidermo
I bought the breakout harness and line levelers a while back. Didn't want to clip factory harness. I will switch the amp out to what you suggested. The speakers are next, see how much overtime i get in the next month. Any issues with mounting power/ground block to biketronics speaker brackets?
Old Apr 26, 2020 | 07:35 PM
spidermo's Avatar
spidermo
So i installed the stinger amp and holy heck, that made a huge difference compared to the previously installed Hogtunes set up. I only have four of six speakers online. I am still awaiting the nvx amp. Space inside the batwing fairing is very tight.
Old Apr 26, 2020 | 11:35 PM
Fireball Jack
I think the NVX fits in the clutch side cubby in a rushmore.
https://www.hdforums.com/forum/audio...n-cb-hole.html
Wild_Hog
Audio Systems
14
Nov 4, 2019 09:50 AM
Baggergee
Audio Systems
11
Mar 18, 2019 08:32 AM
bzmannn
Audio Systems
Oct 30, 2018 06:49 PM
vtdiesel
Audio Systems
May 1, 2017 06:20 AM
Molarman
Audio Systems
Jan 19, 2013 02:45 PM
