Correct Fuse Size
Old May 17, 2020 | 09:48 AM
rock92's Avatar
rock92
Default Correct Fuse Size
I am considering changing my amp to the Sound Digital Evox 2400.4 in the 4 ohm version. On their website, the recommended line fuse is 140 amps. Has anyone used one this big, where do I get it, and is there another alternative such as a circuit breaker?
Thanks for the help.
Old May 17, 2020 | 01:56 PM
travelingypsye's Avatar
travelingypsye
i have not used that amp yet but if they recommend 140 then that make me think it uses a lot of power to run it. If you use lower amp fuse and it doesn’t blow then you are better off anyway. If it were me I would try a 60. If it blows then up it to 100 but that’s just me.
Old May 17, 2020 | 02:02 PM
Makdaddy's Avatar
Makdaddy
fuse size depends on cable size and amp draw from the amp
Im running 2 amps with 40 amp fuse each
thats 4 gauge wire feeding to distro blok and 8 gauge after the 40 ampfuse to each amp
that size fuse seems way to high to me
Old May 17, 2020 | 02:31 PM
IBE's Avatar
IBE
must be a massive power wire feeding that system. hell the biggest breaker in my main fuse box for the whole house is 100 amp breaker
not saying they are wrong or anything just thinking out loud i guess radio systems might go that high in the car shakers
ok just went and did some searching and yes indeed they call for fuses that big. who would have thunk it. ill bet the battery hates it
Old May 17, 2020 | 03:36 PM
rock92's Avatar
rock92
another option is to bridge an evox 400 to the fronts and bridge an evox 800 to the rears. those would have less current draw and would be a cheaper total cost. any thoughts?
rsking45
Audio Systems
Mar 4, 2018 01:19 PM
Houston_t
Audio Systems
Feb 20, 2018 06:47 PM
bikerdad57
Jul 27, 2016 12:44 AM
kdawg187
Audio Systems
14
Apr 7, 2014 12:48 PM
springer3
Audio Systems
Mar 27, 2012 09:19 PM
