Wiring Confirmation
Old Jun 7, 2020 | 02:43 PM
GunslingersNation1's Avatar
GunslingersNation1
Default Wiring Confirmation
So, I bought an ExoX 1200.4. At 12.6 volts, it puts out 200 watts at 4ohms and 300 watts at 2ohms. My plan is to use channels 1 and 2 for my rear WDX8motos to their own channel. Channel 3 in parallel to lowers (SV165S) and channel 4 to fairing Mmats 601.4. I am a little concerned that the wattage is too high for the mmats, so I can cut the low and high pass to give it some extra room. Any other ideas? At the moment, I don't have any other 6.5s laying around. My horns will still run off the SD 250.2.
Old Jun 7, 2020 | 03:12 PM
InthewindMN's Avatar
InthewindMN
Reduce the output to the mmats in the dsp.
Old Jun 7, 2020 | 03:25 PM
GunslingersNation1
Yeah I can do that. If my math is right, turned on, the channel will get about 375 at 2 ohms, so call it 182 watts per speaker. Maybe -1.5 or -2 db should do it. I bet the Hertz finally wake up.
Old Jun 7, 2020 | 06:17 PM
scooper321's Avatar
scooper321
So you're running both lowers in parallel on channel 3? And both fairing speakers in parallel on channel 4? You lose the left right stereo that way...
Old Jun 7, 2020 | 06:21 PM
GunslingersNation1
I am aware of that. It also gives me the advantage of getting away from 3 amps, and still controlling the power output from the location. I'm not putting together a show bike, just one I can hear loud and clear at 80+.
Old Jun 8, 2020 | 12:28 PM
SBates08's Avatar
SBates08
Who needs stereo on a bike anyway!!!
Old Jun 8, 2020 | 01:56 PM
GunslingersNation1
Hell, my ears are so bad, I'm lucky I can hear them at all.
FrenchieM's Avatar
FrenchieM
Some people claim they can hear the difference but I doubt that at speed.
Old Jun 8, 2020 | 03:54 PM
regrol1970's Avatar
regrol1970
I think that same guy has ports on his lowers and got into a pi$$ing match with BabyBoy on fakebook. Stereo is overrated!, Especially if you are try to squeeze as much power out of your amps as possible. Although if they paid for a 1200 watt amp and only use 700 watts of it, that is on them.
What's the old saying? (The 7 P's) Prior Proper Planning Prevents Pi$$ Poor Performance!
Old Jun 8, 2020 | 04:09 PM
FrenchieM's Avatar
FrenchieM
Flapper boy yes!
