Upgrade Question
Old Jul 15, 2020 | 03:10 PM
doctorgoo's Avatar
doctorgoo
Default Upgrade Question
On my Heritage I currently have Polk DB652's on the crash bar and DB692's in the bag lids. These are connected in parallel to a Power Acoustik RZ2 1300D. I use an Ipod as my head unit. Around town this works good enough for me. However, anything over about 60mph I have to crank it up to hear it. It's loud enough but the sound quality really suffers. In order to get a good clear sound which should I try first: upgrading the speakers or upgrading the amp? Or am I pretty much looking at a complete do-over?
Old Jul 15, 2020 | 03:54 PM
Fireball Jack's Avatar
Fireball Jack
Well sound at speed is difficult Do you have the fronts on one channel and the 6x9 on the other?
Old Jul 15, 2020 | 03:55 PM
SBates08's Avatar
SBates08
I would start with a better amp for sure. Those specs for that amp are extremely overinflated. I would eventually change the speakers as well but for now a better amp would serve you well.
Old Jul 15, 2020 | 04:06 PM
doctorgoo's Avatar
doctorgoo
I have the lefts on one channel and the rights on the other.
Old Jul 15, 2020 | 04:13 PM
SBates08's Avatar
SBates08
That's a huge mistake. Never parallel a 6.5 and 6x9 together.
Old Jul 15, 2020 | 04:18 PM
doctorgoo's Avatar
doctorgoo
Thank you.
Old Jul 15, 2020 | 04:31 PM
doctorgoo's Avatar
doctorgoo
Any recommendations on amps? I started with a 2 channel amp because I was going to run just the bag speakers. I came back and added the fronts because I couldn't hear over the wind. I'll be going 4 channel this time around.
Old Jul 15, 2020 | 04:35 PM
SBates08's Avatar
SBates08
Watch Amazon for the price on the Stinger 700x4 to drop down to around $180. It's marine rated and small and will work perfectly did you.
Amazon Amazon
Old Jul 16, 2020 | 03:52 AM
Fireball Jack
The stinger is a great amp at 180. If you cant get it at that the SD 800.4 would work great and has a lot of power.
Old Jul 16, 2020 | 10:13 PM
scooper321's Avatar
scooper321
SD 800.4 gets recommended a lot. But WHICH one? There are several models, right?
